Question about Panasonic NN-L931WF 1200 Watts Microwave Oven
Hi, I have a 1200W 44 litre Panasonic Microwave Oven model NN-S752WF. My wife was cooking some vegetables when she called me. The vegetables were still cold and there was a burnt plastic / insulation type smell and the top cover of the microwave on the right hand side behind the control panel was too hot to touch. I disconnected the power lead and after it cooled I removed the cover. The only thing I could see that looked burnt was the plastic shroud that holds the light on the left of the magnatron. The bottom part of the white plastic shroud at about 2 o clock above the shroud securing screw, is melted onto the bottom left of the magnatron. I have since put a glass of water in the oven to try it. I set 1 min, started it and noticed the light did not come on and it stopped after about 20 secs with no beeping and the glass of water was still cold. There you have it now please what is the problem and how to fix? Thank you, Rick.
  • 1 more comment
  • polmarik Apr 10, 2011
    Hi Paul, I appreciate your concerns. I was just wondering if in fact it was the magnatron at fault or something else that maybe controls the magnatron. If it is the magnatron itself I know I can get a new one and install it easy. It is just with the cost of a new magnatron I want to make sure first before I get one. What are your thoughts.
    Thanks again,
    Rick.
  • polmarik Apr 11, 2011
    Hi I would like to get at least 1 or 2 more opinions as to what my problem is with my 1200W Panasonic microwave model NN-S752WF is please.
    Thank you very much,
    Rick.
  • polmarik Apr 18, 2011
    I installed a new magnatron and so far all seems to be working well.
    Thank you,
    Rick.
  • Panasonic Master
  • 17,129 Answers
It seems to me that the magnetron has burnt and failed. So if there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. If there is soft spots on the magnetron and visible damage seen on the magnetron then it has failed. Finally after drying and a full clean up ,
keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron is faulty. replace with same type.
Posted on Apr 11, 2011
  • 456 Answers
Hi.
any signs of extreme heat, that close to the magnetron, could suggest a fault in the magnetron itself.
this is not something i would recommend trying to repair yourself due to the risk of radiation emission.
any problems near the magnetron, should be repaired by a microwave repair engineer who can test the machne to ensure that there is no harmful radiation emitted.
sorry i cannot be more helpful with this, but i feel that this is something that needs to be repaired professionally for safety reasons and i would not be acting responsibly if i encouraged you to try this repair yourself
Posted on Apr 10, 2011
  • paul miles Apr 10, 2011
    hi.
    to get that hot, my guess would be a magnetron fault, but the wiring around the light fitting should be carefully checked as well
During cooking,microwave stopped,no power.
Not good news; Panasonic uses a technologically superior power supply with higher efficiency but an overall worse record than those using a 'linear' supply with far fewer parts and a good track record of reliability.
The modern (switched mode) power supply places a lot more stress on components and requires more and higher quality parts than the old-style circuit.
Feb 21, 2015 | Panasonic NN-SD681S - Genius Prestige...
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Light nn-sa651s
Panasonic FAQ:
The microwave oven model NNSA651S was manufactured in a way that the oven light turns on only while cooking. - FT
Stupid design!!
Feb 19, 2013 | Panasonic NN-S541 Microwave Oven
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
My Panason NN-C994S is on demo mode and I am unable to switch it back? Do you have instructions to convert back to cooking mode. Thank you
If you go to the Panasonic site you can download the manual.
www2.panasonic.com/consumer-electronics/.../model.NN-C994S
Regards
Alan Hood
ami-man
UK
Apr 05, 2010 | Panasonic NN-C994S Convection/Microwave...
Panasonic NN-T990SA mfg 2002 Door opens, tray continues to spin-light on-fan on--not cooking.
call the toll free number for the product, service centre might assist, I would not use until fixed
Sep 03, 2009 | Panasonic NN-T990SA Microwave Oven
Intermittent heat in microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgssg
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
What cause the wattage difference?
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
- Jim
Feb 17, 2008 | Panasonic NN-S561 Microwave Oven
Pansonic model nn-p295 over the range microwave oven
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 28, 2007 | Panasonic NN-P294SF Microwave Oven
Panasonic NN-L931WF 1200 Watts Microwave Oven Logo
161 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
