Question about Frigidaire Affinity ATF6000F Front Load Washer
Frigidaire Affinity Front Load Washer ATF7000FSO, build date 5/2007. Error code 31. We recently experienced a power surge and and both control boards were fried. I replaced them and now get error code 31, Pressure Sensor not Communicating with Control Board. I can not find a pressure sensor on any exploded view diagrams, only a pressure switch, but the switch location is not even shown. Where is the sensor,and how do I order one if it is bad if I can't locate the part number?
  • 1 more comment
  • jjak909 Apr 11, 2011
    A little more clarification would help, please. While facing the washer, is this the 3/4" plastic tube that comes out of the top, centered, and in the front of the unit? This hose goes upwards and to the left and enters the bottom of the dispenser unit. I do not see any electrical connections to the control board from here that could be causing my error code.
    While facing the unit there is some 1/4" tubing on the right side of the tub, coming from below and up to a round cylindrical housing anchored to the r/side of the washer cabinet. This housing does have a short electrical connection to the control board.
    With the part number you provided I was able to locate a picture of it online. Thank you for your help.
    Quick, thorough response. Much appreciated!
    President:
  • 2,468 Answers
You are absolutely correct,but this component is very easy to locate part#F- 17 on an inset drawing in a frigidaire manual and you will find it at the end of the pressure sensor tube used to fill the tub,there is a plastic tube off the tub going upwards towards the top and the other end is connected to what you are looking for: part# AP4298882 @ $45.00+ S+H
Posted on Apr 10, 2011
  • danny Hendrickson Apr 11, 2011
    this pressure diaphram has nothing to do with the dispenser unit,and normally are toward the rear of the tub,it normally has a flexible plastic hose from the lower outer tub up through the top cover under the control panel to this diaphram,the second issue you spoke of with the round cylindrical housing is the pressure sensoe/diaphram,you found it,
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Frigidaire affinity error codes
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Mar 12, 2015 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
E72
Hello Don, this is Z! Thank you for your post!
I see that your Frigidaire washer is displaying error E72. Have you recently moved your washer to a different location or have the hoses been removed? If so, please verify that the hoses are connected to the correct valve. Otherwise, I would suggest contacting a professional to accurately diagnose your washer since it may possibly be experiencing a communication problem with the control board of faulty valve(s). Hope this helps!
Mar 28, 2014 | Frigidaire Affinity ATF7000ES Front Load...
E00 code what does this mean
Hi William, thank you for your post!
If you are getting error code E00, it usually indicates that your washer is experiencing a generic error. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code
Nov 29, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire fafw4011lw error code 1.30
Hello warnerperry6 - Based on the symptoms you are describing the unit could possibly either have a faulty User Interface Board or Main Control Board. You may try and reset the washer by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Apr 19, 2013 | Frigidaire Affinity ATF7000E Front Load...
How do I remove the washer paddle on my frigidaire front load washer
Hello - Generally speaking, there is not a paddle on a front load washer however there is a "vane" which is where the water comes out of. What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to run diagnostic on frigidaire affinity ATF6000ES front load washer
Hello Tony bent - What issue is the unit experiencing exactly? Can you tell me if it is displaying any specific error codes? If I know more information on what the issue is, I can try to better assist you further.
Sep 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Error code ESE
This is a problem whith your speed controll replace the the speed controll in the bootom of the washer
May 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Jan 08, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF6000F Front Load Washer Logo
406 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
