Question about Canon PIXMA MP470 All-in-One Printer
Paper feeds incorrectly the feeder is pulling to the left and causing the paper to jam or to tear.
    Guru:
  • 352 Answers
Sometimes dried ink on the roller causes it to incorrectly "grip" the paper, making it slip in one section and pull to the side, Check the rollers for Ink and other dirt.
Also try less paper in the feeder, it may simply be too much and is not able to feed it correctly.
Hope this helps GM
Posted on Apr 10, 2011
How do I fix a printer error
turn the printer off..then after a while it turn back on, the jammed paper will come out automatically if it doesn't pull the paper towards you not the other way pull it forward until it is totally outside the exit tray.. dont pull it on the feeding unit cause it will damage the feeder unit and the paper might tear apart leaving a piece of it inside that would be more difficult cause you have to open the entire printer unit.
Oct 02, 2014 | Canon PIXMA Office Equipment & Supplies
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    The printer keeps telling me it's out of paper, which it isn't
    1> Open the sheet feeder cover and pull out the paper support.
    Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
    Pinch and slide the paper guide to the paper's left side.
    Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
    Pull down the paper output tray supporting with both hands.
    Pull out the extension completely.
    Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
    Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
    If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
    Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
    My Ip90 won't feed paper when I try to print a job.
    If the paper does not feed properly it could be due to the follwong causes.
    Cause 1 : Inappropriate paper type used
    Action : * Check to see if the paper you are printing on is too thick or curled.
    * Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
    Cause 2 : Paper Feed Roller is dirty.
    Action : Follow the steps described below to clean the Paper Feed Rollers.
    If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
    1) Ensure that the printer is turned on and there is no paper loaded in the printer.
    2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
    The paper roller rotates as it cleans.
    3) Repeat this cleaning operation one more time.
    4) Load a sheet of plain paper in the printer.
    5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
    Cause 3 : Paper jams.
    Action : Remove the paper according to the following procedure.
    1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
    * If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
    Caution: Be careful not to touch any components inside the printer.
    * If you cannot pull the paper out, turn the printer off and turn it on again.
    The paper will be ejected automatically.
    2) Reload the paper into the printer and press the RESUME/ CANCEL button.
    If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
    Hope this helps.
    Please rate my response.
    Thanks
    Have a good day.
    Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
    The paper is jammed..
    Cause and solutions for paper jams
    Cause 1 : Paper jammed in the Paper Output Slot, the Auto Sheet Feeder, or the Front Feeder.
    Soultion : Remove the paper following the procedure below:
    1) Slowly pull the paper out, either from the paper source or from the Paper Output Slot, whichever is easier.
    * IF the paper tears and a piece remains insde the machine, open the scanning Unit (Printer Cover) and remove it.
    After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off and turn it on again.
    -Be creful not to touch the components inside the machine.
    *If you cannot pull out the paper, turn the machine off and turn it back on. The paper will be ejected automatically.
    2)Reload the paper in the machine, and press the OK button on the machine.
    If you turned off the machine in step 1 all the print jobs in queue are cancellled. Reprint if necessary.
    if you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after moving the paper, contact your Canon service representative.
    Cause 2 : Landscape credit card-size paper jammed inside the machine.
    Action : Do not load credit card-sized paper in the landscape orientation.
    Slowly pull out the paper from the Auto Sheet Feeder and remove it. If you cannot remove the jammed paper or the paper jam error continus after removing the paper contact your Canon service representative.
    Cause 3 : Paper jammed inside the machine at the transport unit.
    Action : Remove the paper following the procedure below :
    !) Hold the Rear Cover Lever and then press to the right and put to remove the Rear Cover.
    2) If you can see the jammed paper, slowly pull the paper out.
    * Be careful not to touch the components inside the machine.
    * If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
    3) Reattach the Rear Cover.
    Hold the Rear Cover so that the Rear Cover Lever comes to the left. Align the protrusions at the right edge of the cover with the slots at the rear of the machine and press on the lever ot reattach the Rear Cover.
    Important : Press firmly on the Rear Cover until it is fit squarely in the rear of the machine. If the Rear Cover is not reattached properly, paper may not feed properly and cause paper jams.
    4) If you were not able to remove the paper out in step 2, remove it from the Front Feeder. Refer to cause 1.
    5) Relaod the paper in the Front Feeder and press the OK button on the machine.
    If you turn off the machine in step 2, all print jobs in queue are cancelled. Reprint if necessary.
    Hope this helps.
    Thanks
    Have a good day.
    Nov 30, 2009 | Canon PIXMA iP1300 Printer
    Canon mx300 printer feeder pulls unevenly causing paper jam
    the left side of the printer pulls the paper causing the printer to jam when trying to print
    Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
    Feeding paper for scanning/faxing - e-studio350
    If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
    Mar 19, 2009 | Toshiba e-Studio 350 Copier
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    False paper jam
    If the paper is lodged too far into the printer and can't be removed:
    Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for inkjet printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
    Canon PIXMA MP470 All-in-One Printer Logo
    219 people viewed this question
    old marine
    old marine
