Question about Magic Chef Kitchen Ranges
Igniter glows bright but oven will not light - Magic Chef Kitchen Ranges
    Scholar:
  • 93 Answers
Still change the igniter, did not draw enough ampage to glow.
Posted on Aug 07, 2008
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
My hotpoint. Has burner activity. The electronic oven will not light, makes no sound when the temp knob is depressed, nor with a match under the burner will it light. Makes no sound through trying each...
Ok
Is your igniter glowing when oven turned on.Look for bright orange glow near burner.If yes ,and no ignition,then igniter is weak and needs replacing.No glow at all,then a voltage test at the igniter needs to be done to see if it might be thermostat problem. Very common for igniters to go.Most likely cause.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
My lower oven does not work. Broiler and all rest work fine? Any ideas what the problem may be? Igniter? Thanks
you are right on the money, the igniter probably needs to be replaced. remove shelves from oven. remove bottom panel. remove flame shield, Turn the oven on and examine the glow from the igniter, it should be a real bright light, and should go from off to bright in a few seconds. If the glow is slow, or no glow at all, then thats your problem.
Mar 23, 2011 | GE Spectra JGBP35 Gas Kitchen Range
Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Apr 27, 2010 | Maytag MGR5750 Gas Kitchen Range
Gas oven not lighting
Hi the problem here is the igniter. Take the floor of the oven out and then the flame spreader. The igniter will be located at the back of the burner. Set the oven for 350, if the igniter does not light then test it with an ohms meter it should read continuity. If it reads open you should replace it. If the igniter does glow it still could be bad, the igniter should glow bright yellow to the point you can't look at it. If the igniter glows orange/yellow it is bad you will need to replace it. If you have any other questions please feel free to comment. Mike
Feb 13, 2010 | GE JGBS20 Gas Kitchen Range
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
Glow plug comes on bright orange but does not ignite gas.
If the bake igniter glows bright grange and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
Oct 05, 2009 | Maytag CWG3100A Gas Single Oven
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kitchen Ranges Logo
116 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
