Question about Husqvarna 965142201 K750 5HP 12" Gas Cut Off
I have a husqvarna k750 sawing stone stawls under load whats wrong?
    Scholar:
  • 54 Answers
If the motor revs up ok it might be the type of disc you are using. I used a huge 2000 Sten one time from about 1961 going through rebar cemented inside cinder block wall to make some windows. It used the huge 18 inch discs and the older guy that was my boss said there is two types of discs - one is tar bonded abbrasives and the other is resin based which is three times better cutting and doesn't smoke up your lungs while you are breathing hard. They are usually dull red with no black in the grit if you look right up close. If the motor stalls or has a cutting out noise at high rev without load it may just be a dust covered gas filter which is deep inside the saw's gas tank on the end of a rubber tube.
Posted on Apr 11, 2011
Broken crankcase on husquavarna k750
Time to buy a new one or order a long block from Husqvarna
No way to fix a broken casing unless replacing the side that is broken.
Nov 04, 2013 | Husqvarna Saws
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
What is the oil to fuel ratio for the quick cut saw k750
generally 50:1 fuel to oil mix is recommended.
Apr 30, 2012 | Husqvarna Garden
Husqvarna k750 wont idle down. I have replaced both rubber tubes and have even replaced the carb.
Replace the crankshaft on both sides. You will need a special puller to remove the seal on the flywheel side and the flywheel.
Sep 27, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
K750 cut off saw three new air filter,gas filter,spark plug saw loses power after 15 sec of hvy cutting
Piston rings are gaulded or stuck, easy to change and fairly inexpensive if you buy aftermarket parts on ebay. I believe piston, rings, and cylinder (if you need it) for less than $100.
Aug 25, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Husqvarna k750 sawing stone starts up fine filters clean stawls under load
Start by changing the fuel filter in the fuel tank, if this does not help remove the top covers and check the impulse pipe to the carb has not become diss connected, let me know if it still is not right.
Apr 10, 2011 | Husqvarna Garden
Husqvarna k750 runs for about 5 mins then shuts off. let it rest then restart 5 mins later same thing
Obevisley is over heating make sure all fins and vents are clear and blown out then the only other thing is to replace the ignition modual just trace the plug wire back to flywheel and ignition block
Oct 06, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
Oil ratio partner k750
40ml to 1 litre of fuel 150ml to to 1 gallon
May 19, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
Husqvarna 965142201 K750 5HP 12" Gas Cut Off Logo
314 people viewed this question
Top Husqvarna Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Husqvarna Measuring Tool and Sensor Expert? Answer questions, earn points and help others
