Question about La Crosse Technology SelfEmptying Rain Gauge
Need replacement parts for LaCrosse Technology Wireless Rain Sensor Model TX58UN-IT
My outdoor temp is slowing almost 10 degrees warmer than actual temp outside. What is problem.
You are using a wireless system that transmits signals between the outdoor sensor and the indoor receiver. They are not a perfect match. You cannot make adjustments, thus if your lucky, the factory matched up the devices prior to the sale. You may contact Lacrosse for a replacement outdoor temperature device.
Jan 11, 2018 | La Crosse Measuring Tools & Sensors
How do I get a new outside temperature sensor?
You may have to order a replacement sensor directly from La Crosse.
Apr 29, 2015 | La Crosse Technology Lacrosse Technology...
TX58UN-IT transmit icon is on, does not measure rain.
I had this problem and after 7 days I've heard nothing back from LaCrosse. Problem appears to be a non-functioning magnetic reed switch inside the circuitry housing. It's easy to remove the cover with a tiny phillips screwdriver (mind the small and delicate gasket/o-ring). Then the circuit board is held in with two more tiny philips screws at the bottom of the housing. Removing and replacing the switch will require a low-wattage soldering pencil. I used a Standex-Meder part number ORD228VL-1015 from Digi-Key. Only a couple $, cheap, fast shipping. It appears to be an EXACT replacement.
Feb 17, 2014 | La Crosse Technology TX58UN-IT Wireless...
So, since you can't fix it, when are you sending me a new one??
Fixya is an independant support site that is not related to the company that you are dealing with. We have no way of knowing what communication you have had with LaCrosse technology.
Sep 05, 2013 | Lacrosse La Crosse WS-9049U-IT Wireless...
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Aug 05, 2012 | Bushnell Measuring Tools & Sensors
Need instruction manual for equity wireless thermometer
Hi George,
I believe your Equity wireless thermometer is manufactured by LaCrosse Technology. Here is a link to their website:
http://www.lacrossetechnology.com/
From this page, you can search the type of wireless thermometer or weather station you're trying to use. (You didn't specify a model number in your request).
Also notice that there is link on that page for Support; clicking that will take you to the Manuals link. You will need to find your proper model number in the drop-down menu.
Also, there is a Contact link, so you can contact them directly for further assistance if you are unable to find your model's information.
Good luck, George! Hope this helps!
Feb 11, 2012 | La Crosse Wireless Thermometer
Equity wireless thermometer instructons
Feb 11, 2012 | Measuring Tools & Sensors
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
La Crosse Technology SelfEmptying Rain Gauge Logo
125 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
john milligan
Oloyede Monsuru
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
