Question about Dryers
Hi, smelled burning from dryer, remove bottom cover and discovered lint fire occured. Cleaned up all lint, removed lint filter cover cleaned and vacuumed all lint inside dryer. Inspected wires and belt for damge. Does not appear to be any damage. Cleaned dryer exhaust and vent out thru walls to outside. Dryer works fine. Anything else I should do? Thanks Dave
    Sergeant:
    Champion:
  • 207 Answers
Its sounds good is the smell gone,if so you did just fine........
Posted on Apr 10, 2011
Testimonial: "Thank You for your expert advice and opinion. Dave"
I also smelled something burning & also discovered once I removed the back panel that there had been a lint fire. I cleaned out a TON of lint that apparently had escaped the lint trap. Problem is my lint trap catches very little lint...even with large loads of towels. This is a bad design on Samsungs part and they should fix it because my dryer is only about 3 months shy of being 2 years old. It's only used to dry on average 8 loads per week. I feel lucky that the fire didn't spread & cause bigger problems.
Posted on Aug 24, 2013
  • 2 more comments
  • Kim Dawson Aug 24, 2013
My Samsung dryer has quit three times and is still very new.....model #DV317AEG....SERIAL#34945BP400401P. For no ascertainable reason, it just quits doing anything. It will refuse to work for four, five or more days and then suddenly comes on again. It's kinda like I have a haunted dryer! It is like there is absolutely no power to it at all, then, POOF, it starts working again. DOES ANYONE HAVE ANY IDEA WHAT IS HAPPENING HERE?
Posted on Apr 13, 2011
I got a burning smell after I cleaned my dryer from Lint.
I have seen this before, cleaning the actual dryer vent trap out is taking the machine apart, I mean taking the cover off and vacuuming the thing out. Just taking the tube off the bottom that goes outside isn't enough some times. We find change and bolts as well when cleaning it "all the way" usually. It could just be residual dust burning from the heat part as well. How is it drying? If the cloths are getting dry at the right amount of time, then you might be OK.
Dec 11, 2017 | Dryers
Lg gas dryer something burning
burning smells in driers can be sometimes from a blocked lint filter. The dried lint has been known to ignite when it gets hot. If you haven't cleaned the lint filter then do so and if the smell continues get it serviced.
Nov 20, 2014 | LG Washing Machines
Lg tromm gas dryer burning smell shuts off
Hello Debi;
My name is Peter. I am a retired field service appliance technician.
You have a dangerous situation.
1.) First, your dryer is shutting down because your dryer is plugged up with lint and there is no air flow. You need to remove the top cover and control panel, the front cover and if your hot air distribution manifold id in the back or front end, remove that and clean. With a dry rag (DO NOT USE LIQUID CLEANERS), wipe the grease and grime off all components.
2.) The burning smell is the lint burning. Fortunately, due to the lack of air, the lint is being extinguished.
So far you are lucky. You have not had a major fire. DO NOT USE THE DRYER UNTIL THE ABOVE TASK HAS BEEN ACCOMPLISHED.
I wish I could provide you with more specific information on your dryer, but you did not provide a model number.
Nov 20, 2014 | LG Dryers
How do ou get to the heating element in a Bosch WTVC533SCN/09
These heaters, and safety thermostats are accessed from the rear of the unit by unplugging the dryer from the wall, and removing all the screws that hold the rear silver panel on after removing the main top. The heater is located in the lower right corner. While the heaters are less likely to fail, you do have a red button reset thermostat that often is the reason for no heat. These resettable thermostats trip for a reason, and become easily strained when tripped even on the first time, a real cause of failure should be discovered regardless what part has gone bad. Home vent systems should be checked by a reputable vent company. Remove the lint filter, and using a flashlight, you should be able to see a tiny probe in the lower left bottom area of the lint filter housing, if it's covered with lint, or even partially covered, this housing needs to be completely cleaned. Additionally the Bosch lint filters themselves are very fine filters, and are subject to congestion by both lint, and residue from dryer sheets. It's advisable these filters should be cleaned with warm water, and a de-greaser like pine-sol or similar to ensure they are breathing properly. Pleazer Appliance...
Apr 11, 2014 | Bosch Vision 500 Series Front-Load Washing...
I pulled out the lint trap to clean it and it was overloaded with lint. Most of the lint fell back and when I turned on the dryer, it blew out but it started making a very loud rattling noise and smelled...
If you are feeling resistance trying to re-insert the lint screen most likely the duct has clogged further down (a load of my husband's shop rags packed mine solid one day). Needless to say it's not safe to run it like this due to the risk of fire.
You can try using a dryer lint trap brush to dislodge the clog. But with it being clogged to this extent probably the best way to make sure it's cleaned out properly is to remove the duct inside the dryer. This would involve taking the back off the dryer and some dissasembly, so if you're not comfortable with doing that please call a professional.
If you feel comfortable with doing this, FIRST make SURE the breaker to your dryer is off and the dryer is unplugged.
1. Turn the dryer around and remove the vent hose from the bottom.
2. Remove the screws to take the back panel of the dryer off.
With the back panel off, you will see the duct on the left hand side that leads from your lint filter on the top of the dryer to the blower housing at the bottom.
3. Remove your lint filter from the top, while doing so note that there are 2 screws right next to it on the top, remove these 2 screws being careful not to loose them in the duct. These hold the top of the duct to the dryer.
4. Next follow the duct down to where it mounts at the bottom to the blower housing, you will need to remove these screws also. there also may be a couple midway up that will be securing the duct in the dryer.
The duct should then be able to be removed from the dryer. Clean it out throughly, be careful, the edges are very sharp in places. Re-install, being careful not to drop the 2 top screws back down into the duct while replacing (you may want to install the lint filter first).
This video shows the procedure of the duct (or airbox) being removed and cleaned with the exception of the removal of the top 2 screws by the lint screen.
http://www.youtube.com/watch?v=VXNOH_8A7xA&feature=related
Feb 13, 2011 | Roper REX4634KQ Electric Dryer
Makes the clothes smell burnt or like a machine smell
your problem is most likely lint build up around the heating element to clean it the element and heat gard need to be removed. or it could be a slipping belt. last it could be your motor burning out though the first diagnosis is the most common to avoid this fault in the future it imperitive that the lint filter be cleaned of all lint after every single dry cycle as this is the most common reason for house fire regarding dyers as well
hope this helps
Jun 30, 2010 | Dryers
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt something burning when I opened the door. I noticed my light catcher was full, could this be the problem?
Yes it could have been the lint igniting in the bottom of your dryer in future clean lint trap after every load and take trap door out and vacumn inside trap at least once a month If you ignore the lint trap you could end up with a serious fire so take care of it when you remove screen a certain amnt of the lint falls down into the bottom of dryer and after time a buildup can ignite.. more serious with a gas dryer as the igniter and burner is at the bottom of most gas dryers
Dec 17, 2009 | Whirlpool GEW9200L Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Burning smell when it is on. Dryer still works
Make sure the duct to outside is not obstructed. Number one starter of fires with dryers.
Apr 15, 2009 | Frigidaire Electric Dryer
Burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Apr 10, 2009 | GE DVL223EBWW Electric Dryer
Dryers Logo
388 people viewed this question
Top Dryers Experts
