Question about Daewoo DVDS151 DVD Player
My Daewoo S151 has stopped responding when I turn it on - the green light on the front comes on, but it doesn't send a signal to the TV. It makes no noise to indicate it's actually on (no tray or lens movement), or it makes this loud, consistent clicking noise. I'm assuming it's a motor problem; I took the cover off to look at it and it looks like there's a gear that's not catching or something. There's no way to open the tray when it's like this because it's acting like it's not on, even though there's obviously power going to it, and it's working enough to make the dreadful clicking nose. Does anyone know how to fix this?
snakehead
  • 1074 Answers
SOURCE: Power light does not come on, no picture . Only sound it makes is when i push the power button
make checks in the all power circuits if you are not a tech take it to a repairman
Posted on Mar 30, 2007
SOURCE: Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
Hi a quick update on this, when I turn the tv on the screen flashes for a split second then turns off? an y ideas anyone?
seems as though it turns on, buzzes then turns off am thinking of drop kicking it!! HELP
Posted on May 20, 2008
SOURCE: Daewoo dvd + VCR
Solution I found was to ignore the coloured signal leads. Simple
Posted on May 25, 2008
mie999s
  • 105 Answers
SOURCE: My Daewoo TV is showing a yellow tinted screen...
this problem actually come from crt socket ic board (just patch behind the picture tube) need to properly clean and resolder back the joint please consult with your tv repairer and i think it not cost much
Posted on Mar 24, 2009
  • 297 Answers
SOURCE: My Daewoo Lanos has a really loud noise in the
Wheel bearings are difficult to tell which of the four at times.
Be sure to be adviced by an old fox in the game. Cars are sound boxes. I had a car and it actually was the last bearing being the guilty one. Wheel and hub bearing is the same to me. And there are other bearings there. Better shop around for cost estimate and guarantee on repair. DIY can be more costly if no mechanic. You pay parts and go about with DIY risks you pay at all times.
And official dealers are not allways the best. Dry not moving plastic hub caps can make a lot of nasty noise at low speed in narrow streets or underground parkings. If you have those get them off clean tyre rims and caps and grease them slight with teflon spray or so. Refit. Cost virtually nothing. Also make up other items coming up fore replacement not to overinvest in old wrecker with corrosion or too high mileage. Maybe your's is fine but calculate ahead. Including totall loss value on accident.
Posted on May 06, 2009
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
On my 2004 impala, the front right turn signal doesn't work, (only works with hazard lights). And the back right signal is fast. The signal "clicking" sound is non stop but on the other hand...
If the turn signal filament of the right front park/turn lamp is known to be OK and the hazard switch is in the normal position, the hazard switch or the turn signal/multi-function switch could be defective
Oct 16, 2012 | Cars & Trucks
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Sanyo dp37819 i turn it on green light comes on but no picture or sound and green light goes on and off
You can send your main board to us and we can give it a try.
If it the front LED turns on for a while, then off for 1-2 seconds and then back on...we'll probably be able to help.
See http://www.coppelltvrepair.com for details and shipping instructions.
Jan 14, 2012 | Sanyo DP37647 37 in. LCD TV
How can I stop my ABS brakes from occasionally activating even when I come to a gentle stop. I coast to a stop, hit the brake, and the front end feels like it's gonna fall off. The sound it makes is...
You can unplug the ABS, and it will be disabled. Doesn't sound like that's the problem, though. Have your front end checked, brakes, suspension, wheels, CV axles, everything. Before it cripples you on the road.
Oct 13, 2011 | 2001 Daewoo Leganza
Hi, my Daewoo Plasma 42"
If the power light stays green then the current absorbed by the different boards appear to be normal. If that is the case then most likely you have a bad contact in the data cables or in the mainboard.
You will need to open the tv, inspect for damage and reseat all the components then (if that doesn't fixes it, you will need to extract the mainboard and check the soldering on the board and the status of the processor.
Jul 24, 2011 | Daewoo DSP4210GM 42 in. Plasma Television
VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Feb 14, 2009 | Polycom VSX 7000 Video Conference
Daewoo won't read remote
Try these codes 10451, 11661, 10092, 10672, 10019, 10623, 10039, 10661
Jan 05, 2009 | Televison & Video
Daewoo dvd + VCR
May 24, 2008 | Daewoo DVRS04 DVD Recorder/VCR
what way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
May 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Daewoo DVDS151 DVD Player Logo
57 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
