Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe not transferring grounds to brew group?
I've had this machine for a few years now and this is the first problem I've had. The grinder works OK, but the system has chosen not to transfer the grounds over to the brew group anymore, so the grinder keeps going until the machine stops and the red light comes on. It never makes it past the initial step of grinding the coffee. Any suggestions?
  • 515 Answers
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Posted on Aug 07, 2008
I cant take out the brew group of my saeco vienna espresso machine
have to make sure the group is in part. turn machine off and on should hear the motor go. if the group is stuck take the small screw out of group and will release piece thats on the injector. MUst hold the lever on the front of the group to relase the lock then gently pry it out .
Dec 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Royal water leaks out and now blows wall plug if plugged in
Clean behind the brew group - pull out the brew group and use a pipe clean in the little water weep hole in the back. then use pipe clean down from above the weep hole - it will be full of very wet coffee grounds.
Dec 27, 2008 | Saeco Vienna De Luxe Espresso Machine
SAECO VD
If you take out the brewing unit and look in the chassis you can see a hole, make sure that hole is clean.
Jul 25, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Vienna deluxe can't get dump box back in - brew group flap in the way
Leave the dump box out. Use a spoon to hit the switch where the dump box would normally hit. Hold the switch until the flap is no longer in the way then replace the dump box.
Espresso Machine Service
www.cerinicoffee.com
Nov 23, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
260 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
