Question about Yamaha Mg3214fx 32 Channel Mixer With Fx System
I installed a Yamaha MG32-14FX sound board. My cordless mics sound so muffled.
Cobra vhf will transmit but sounds very muffled or weak. Sounds like I'm several feet away from mic. I receive fine. Just transmitting problems. I have already replaced mic
I have the same problem with my midland 9001z.I've changed the mic,the coax the antenna the only thing I haven't done is on the inside.I don't want to tackle that until I get a service manual for it. Now what kind of cobra are we talking about?
Apr 29, 2014 | Radio Communications
Why mic sound muffled
Depends on what you mean by "muffled". Internal microphones and standard external ones are not high quality mics, but that sound I would describe more as fuzzy. So if you could be a little more descriptive I could help further.
Sep 03, 2013 | Samsung Computers & Internet
Why does it sound so bad?
It's probably the mic, or you have some mental condition. I'm going with the mic, try returning it and getting a new one and if there's no difference, then try the software you use on whatever it is you're recording it with.
May 27, 2013 | CAD Microphones GXL2200 Professional...
Microphone muffled
Try to talk with your lips touching the mic . If there is any improvement open the mic housing very carefully and bring the capsule as near as possible to the top part of the housing .
hope this helps.
Sep 08, 2012 | Logitech USB Desktop Consumer Microphone
Sound gets muffled at certain frequencies. Please Help!
I think that rather than the mixer, that your front speakers may have a limiter built into the high frequncey amp. You may be asking them to do more that they are capable of.
Mar 04, 2017 | Behringer Sx2442fx Eurodesk 24channel...
Shure SM58 A singer has joined me with her own SM58 ,i have to turn the volume up much higher on mine ,with a more muffled sound .This is causing a prob .The PA is a Yamaha Stagepas 300
Please get the microphones checked seperately If there is an impedance difference orr if the coil is damaged then this difference of sound is possible.
So just check it out or else replace the mic.
Sep 13, 2010 | Shure SM58 Professional Microphone
The mic play back sounds deep and muffled , i was online chat and when i set up the mic volume, it played back deep and muffled like on the movie silence of the lamb.
Its set too loud and the mic is way to close to your mouth. try seeting the boom mic about 2inches from your mouth!
It's a matter of experimenting with mic placement to get the best results. (If it'sd not a new unit, make sure that the microphone holes underneath the windsock aren't blocked up with debris!)
Good Luck
Jan 17, 2010 | HP RF823AA#ABA Headset
Muffled sound
It is possible that your cell phone has gotten something covering the mic or dirt has gotten into it. There is a piece of felt that is used near the mic area. It is possible that it has moved or was never in the correct place. In order to know a person with experience would need to take th phone apart to check the mic area. Or you might just want to have a new mic added.
Jan 10, 2009 | Motorola Mobility RAZR V3
My microphone sounds muffled
Check wind screen. Make sure output level is not higher than volume level.
Dec 09, 2008 | Samson C03U Professional Microphone
Gem Amplifier and cordless mics
If the wireless mic has an XLR output that matched the corded mic input, the answer to your question is yes.
Dan
Jun 15, 2008 | Gem Sound Audio Players & Recorders
Open Questions:
Yamaha Mg3214fx 32 Channel Mixer With Fx System Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
