Question about Ricoh Aficio 1035 Copier
High voltage board always revealed 395 when i unpack it some one help me please
  • 1 more comment
  • santosj27
    santosj27 Apr 11, 2011
    Give more info.
    What are you trying to do???
    395, is a SCode???
  • plagio omar Apr 11, 2011
    this problem happened when ground terminal is not set properly
  • plagio omar Apr 18, 2011
    manual not only write all solution for problems i 'm technician and i know every model and problems
  • 263 Answers
A development bias leak signal is detected.
Check this
Posted on Apr 11, 2011
  • 1 more comment
    this happened only in big machine 55 65 85
  • santosj27
    santosj27 Apr 13, 2011
    Sorry! Did you check what the manual says????
  • santosj27
    santosj27 Apr 20, 2011
    I can see that you are a technition.
    And i also see that you must be... GOOD!
    Just for clarify: Why did you post a question????
    You know every model and every problem...
    Also i saw your rating. Its... GOOD!
    Now i know how is responsible for my past ratings.
    I just whant you to know that i do this for helping not for money. You can rat me like you whant.
    I dont care.
    See you Technition.
    Sorry... GOOD technition
Sc code 395 on aficio 1035
Possible Causes
• High voltage supply board defective
• Poor connection at the development
bias terminal
• Poor connection at the high voltage
supply board
Jan 23, 2013 | Ricoh Aficio 1035 Copier
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
I I HAVE A philips 42pf5320/10 IT TURNS ON GREEN LIGHT IS ON BUT THERE IS NO BACK LIGHT, NO ONSCREEN DISPLAY, NO PICTURE.
Hi.
If your TV is LCD this are the procedure/steps to fix your problem.
Half picture on top of the screen, and the bottom half is black it means the back-light of your TV on the bottom is not working.
This are the step on how to find the trouble of your TV:
First, you have to remove the back cover of your TV to see the internal parts inside.
Secondly,after you open the back cover and the internal parts will reveal.Try to find where is the power supply board.It is usually connected to the power cord and it have a AC input that connects directly in you outlet.
It look like this:
This image is not exactly looks like your power supply because you don't indicate the brand name and model # of your TV.
Thirdly,plug-in the power cord then power it ON and be careful,check the output voltage of the power supply using a multimeter (range in DC) ,if it is have a 24vdc for the supply of inverter board.It is the board that gives a high voltage to the back-light of LCD TV.
Fourthly,if the power supply got the reading of 24vdc it means the power supply is good.Then try to check the input voltage of the inverter if it is have 24vdc.
The inverter looks like this:
This image is not exactly looks like your inverter board because you don't indicate the brand name and model # of your TV.
Fifthly, if the inverter have a input voltage please check the output voltage of it.It should have 500vdc so be careful to perform the voltage data in that point because it has a high voltage or hot area.
NOTE: if you don't have voltage reading on the input of the inverter board (24vdc) and the power supply an output of 24vdc,please check the wire that connect to each other.
Sixthly, If the inverter board have a reading of 500vdc on all outputs connectors (it is usually have 4 to 6 outputs).Your back-light lamp at the bottom are busted replaced it.
Or if your inverter board doesn't have a output voltage replace it.
You can buy the parts here:
Just click this direct link. http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=SFNT&Store_Code=EU
Or here:http://www.shopjimmy.com/
And also to eBay.com at your search engine.
Reminders:
If you don't have any basic knowledge about the electronics and testing equipment please don't attempt to do this steps.Its better to send it to the qualified technician or on the authorized service center of your TV.
If this solution will help you to fix your problem,please don't forget to vote and rate my answer.Thank you and good luck
May 08, 2011 | Televison & Video
Hi.
It look like this:
Reminders:
I hope this solution will helpful.Thank you and good luck.
May 01, 2011 | Televison & Video
Unplug TV will come on.cannot turn TV on
Hi, please chech does the screen of your TV lights up?during power on?if not then there might be a problem on the inverter board and the backlight lamp of the monitor .The lamp is a cold cathode bulb it requires a high voltage supply from the inverter board in order to light up.just like any other bulb this lamp has a limited life span more or less 2 years of continues lit.The inverter board is a high voltage board the power input of this board is 24volts DC and the output is 200volts AC.The terminal input of this board or connectors must be check because of high voltage corrosion and loose connections always happen that leads to the mal function of the display or screen failure just like what happen to your TV.
Backlight lamp is installed at the top and bottom of the screen you need to open the back cover of your TV to check up the lamp.(make sure to unplug the TV before proceeding)..check first the test point that I mentioned then post back for your findings then will proceed to further trouble shooting.
I hope this will be helpfull to you. GOOD LUCK!
Feb 02, 2011 | Sanyo Televison & Video
Richocopier giving error 395
high voltage board is defective that happend when paper sheet becom very black and bias is leak but it's often be high voltage board
Jan 15, 2011 | Ricoh Aficio 450 Copier
395 code
395 Development output abnormal A development bias leak signal is detected. High voltage output to the development unit exceeded the upper limit (65%) for 60 ms. High voltage supply board defective Poor connection at the development bias terminal Poor connection at the high voltage supply board
if you change the developer and initialize'it it should work,if not do the above.
Jun 29, 2010 | Ricoh Aficio 1045 Black and White Copier
395 Code in 1035????
Jun 18, 2010 | Ricoh Aficio 1035 Copier
My ricoh aficio mp3010 suddenly only gives my blanc copy's.( I allready changed the toner, but stil no succes. could someone please advise. thanks.
Your problems into the high voltage unit.Please check the carge corona (wire & holders&grid),inspect transfer bellt (under belt HV board,inspect and vacuum cleaning the toner and dust).Pull out the image unit ,rotary manual magnetic rolls to see a developer status,and reinstal the unit.
Aug 02, 2009 | Ricoh Aficio 450 Copier
Projection television
Most likely a high voltage leak. Is the static on menus as well? If there is a leak of high voltage, you should be able to hear it as well. Some of these sets leaked coolant from the picture tubes. A close visual inspection of all printed circuit boards should reveal this.
Mar 03, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Ricoh Aficio 1035 Copier Logo
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
