Question about Lexmark X3650 Printer
How do i change my ink cartridges in my kexmark x3650
  • Official Brand Answer
  • 3,344 Answers
Ikkenom is correct. But let me add something to it. Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below: 1. Unplug the printer from the power source. 2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer. 3. Remove the used cartridges. 4. Load the new cartridges. Close the cover. 5. Plug the printer back to the power source.
Posted on May 03, 2011
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-head will slide to a position from where you can "unlock" and then remove an ink-cartridge.
Posted on Apr 14, 2011
My lexmark x3650 printer will print, but the pages come out blank. did a test to see if there was no ink and the diagnostic said 40% ink is still in there.
Try this approach instead:
  1. From the printer operator panel, press Setup button.
  2. Select Maintenance.
  3. Select Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
  4. Once the test page is complete, try to print your document again to verify that the print quality has improved.
Aug 21, 2011 | Lexmark X3650 Printer
Brand new ink cartridge for Lexmark X3650. Error message to remove tape from cartridge. Tape has been removed. Print alignment prints in only black and same thing on cleaning process.
You can try to manually wipe the cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. You can also clean the nozzles using the Lexmark software on your computer. If you're using Windows, go to Programs/All Programs > Lexmark 3600-4600 Series folder > From the printer folder, click Maintenance > Clean Cartridges > Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
May 27, 2011 | Lexmark X3650 Printer
How to install ink cartridge
You can download the Lexmark X3650 user's guide from the Lexmark website using this link: http://bit.ly/a4dw5s. Scroll to page 93 for the instructions on how to install the cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Oct 05, 2010 | Lexmark X3650 Printer
Replace ink cartridge/ IBM SELECTRIC III TYPEWRITER
A picture is best, goto kexmark.com, click on support and without to much difficulty you will find a downlosdable manual.
DickyO
May 17, 2010 | IBM Office Equipment & Supplies
I have a Lexmark x3650, I just changed the ink cartridge and still get a message that cartidge is low on ink. How did I fix this?
Maybe the cartridge is not seated well in the carrier or just needs cleaning. Remove the cartridge from the printer. Follow these steps in manually cleaning the nozzles of the cartridge.
If problem persists, it's probably a defective cartridge. You might want to contact Lexmark Technical Support for assistance since it's a brand new cartridge.
May 03, 2010 | Lexmark X3650 Printer
Lexmark X3650 all-in-one Printer, have refilled colour cartridge with inkjet refill kit but still indicates low-ink level, and will not function. Do I need a resetter?
Go to all in one program
at the top left click on Maintain\Troubleshoot
Right window click on Device Status And Ink Levels
that will open a new window
Click on The button that looks like 4 different colored ink drops
Click on Install a new print cartridge
Click on Next
Now you should be in Select The cartridge installed
Open lower drop down window and click on No its new
Follow the prompts from there or click OK
This should fix the problem.
Oct 21, 2009 | Lexmark X3650 Printer
Refilled cartridge, still says it's empty and won't print
Sometimes when cartridges are refilled they won't always work because the ink has dried inside the nozzles and therefore no ink will come out and the printer's ink circuit detects no ink and indicates the cartridge is empty. Also sometimes the Print Head itself will clog up with dried ink and cause this very same problem. You can probably buy a new inkjet printer cheaper than you can have this one repaired. If you can afford it I would recommend replacing it with a Laser Printer that uses powdered toner, they last a lot longer and are more economical to operate than an Inkjet printer.
Aug 23, 2009 | Lexmark X3650 Printer
Refill on lexmark x3650
Not positive, but I read in a forum recently that this will NOT work with this cartridge.....if u find out, let me know. I need ink too....:(
Jun 28, 2009 | Lexmark X3650 Printer
Refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
May 16, 2009 | Lexmark X3650 Printer
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
Lexmark X3650 Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
