Question about Vacuums
The Lifesaver smoke alarm model 1225 is hard wired, no battery and is chirping. I have it pulled out with wires coming out of the back, but can't open the front face to get in to disconnect the wire. Anyone know how to open it up?
  • madrasman Apr 11, 2011
    Tried twisting to open it. There is no give. It hasn't been opened for alomost 19years. May be it is just stuck. Time for the sledge hammer option, I guess.
    President:
  • 1,515 Answers
Hi, you should be able to grasp it and twist it to open/remove it from the juntion box to expose the 120 volt wires. They do not open like one with a battery type, so twist it I believe CCW to remove it from the box to disconnect the wires. Please be careful, wouldn't want you to get a shock!
Shastalaker7
Posted on Apr 10, 2011
  • Robert Horton
    Robert Horton Apr 11, 2011
    It shoud be connected directly to the electrical box. You will need to replace it anyway, so if you see no screws at all holding it to the box, and its been on there that long, I would get something with some leverage and twist it off to get to those wires. They will have wire nuts on them so there is no chance of shock. Give it a shot.
    Shastalaker7
  • Robert Horton
    Thank you for the awesome rating,
    Shastalaker7
Replaced smoke alarm battery and also took down from ceiling--still chirping every 30 seconds. Any thoughts?
The chirping is definitely the low battery warning. Are you sure the battery you put in was good? I would definitely double check the battery using a meter.
Jun 26, 2011 | Vacuums
Tip
How To Replace the On / Off Switch On Hoover Windtunnel Self-Propelled Uprights
What you'll need to do this repair:
- Phillips head screwdriver
- Needle Nose Pliers
- Hoover Windtunnel Switch For All Upright Models
Step 1. Turn the vacuum cleaner around so that the back is facing you. Remove the two screws at the top of the vacuum that are holding the handle on the machine. Please see the picture below of the two highlighted screws that need to be removed;
Step 2. After these two screws have been removed, simply slide the handle backwards, and remove it completely from the vacuum and set it aside. You now can see the on/off switch, but you can't easily change it from here, you'll need to complete several other steps before you can remove the switch. Here's what the vacuum should look like after removing the handle:
Step 3. After removing the handle from the vacuum, turn the machine around so the front of it is facing you. Open the vacuum bag door and set the door aside. Also remove any attachments that are on-board in the tool storage bin, this model has a hand-held turbo brush stored here. After removing both of these parts, you'll need to unscrew 3 screws that holds the tool caddy onto the vacuum cleaner. I have circled the area where these 3 screws are located:
Step 4. After removing these three screws, pull the tool caddy off of the vacuum by pulling straight forward by using the tool caddy lid. You'll now have access to both the front and the back sides of the switch. Use your needle nose pliers to remove the two wires that are attached to the switch. Be careful when pulling these wires off because if you pull too hard, then it will break the switch terminal off inside of the wire. Most models have the wire that has a plastic covering over the end of it on the top, and the metal terminal is connected on the bottom. The two lead wires that need to be removed are highlighted:
Step 5. After the wires have been removed from the switch, turn the vacuum back around so that the back of the machine is facing you. Simply use your flat head screwdriver to pry the switch off. You may push on the back side of the switch where the wires connect to it in order to give a space so that you can get a screw driver behind it. Here's how it should look:
Step 6. Once the old switch has been removed, simply push the new switch into the open hole. Important: Make sure that the Off setting of the switch is at the bottom, and the part of the switch that says on is on the top, otherwise the switch will be reversed. Re-attach the wires to the switch, with the wire that has the plastic covering on top, and the metal wire terminal on the bottom. The only tricky part of reassembling is when you put the handle assembly back on the vacuum. As you can see, there is a metal cable below the switch. This metal cable controls the self-propelled mechanism. If you look at the handle assembly, you'll see where the self propelled cable sits inside. The easiest way to line these up is to pull the cable up to the top, and then line up the rod inside of the handle that the cable goes in, and slide the handle back on the vacuum.
I hope this was helpful.
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover U6476-900 WindTunnel Vacuum
Tip
How To Replace the On / Off Switch On Hoover Windtunnel Self-Propelled Models
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover U6630-900 WindTunnel Bagless...
Lanson smoke alarm model LANSD240B S/N 139606 Alarm alert beeping. Replaced battery, tried 2 new battries, still beeps. No smoke or fumes found.
try this, remove the unit and take out the battery you will see 4 small rubber plugs in the back.
remove these and take out the 4 screws, you will find a lot of dust and insects in there, gently blow out with compressed air and the sensor as well.
I did 2 problem ones in my house and now they are working fine
Feb 18, 2011 | Vacuums
Tip
How To Change The On / Off Switch On Hoover Windtunnel Self-Propelled Models
Chris J.
GoVacuum
on Apr 10, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Hi I have a wired kidde alarm with a lithium battery. The alarm keeps chirping. How do i replace?
Most of these types open from the side, or have a press-to-release mechanism that operates similar to a ball point pen clicking mechanism. Most have the release directions embossed on the casing; feel around for the raised print.
Regards,
--W/D--
Jan 13, 2011 | Vacuums
Smoke alarm keeps chirping. put in new battery and continues
The sensor inside can go bad and that is not repairable...
you may need to replace the smoke alarm..
heatman101
Sep 05, 2010 | Vacuums
Our carbon monoxide dectector model CO910, bought several years ago (10+) beeps every 30 seconds with an "err" message. All windows where it is are open. No one is feeling ill. Is it just an error on...
CO2 and Smoke detectors have an internal sensor that has a design life of 5 years from the date of manufacture. After the 5 years you start getting false alarms due to the sensor itself exceeding its average life span. On the combination CO2 and Smoke deterctors you will often see a manufacture date or a replace by date inside the cover on the main board.
On AC powered models such as this one you will just get the error when the sensor fails. If you got the full 5+ years out of your CO2 sensor then you should be happy that it served a full life expectancy.
Some Wiki data on CO2 detectors:
http://en.wikipedia.org/wiki/Carbon_monoxide_detector
This paragragh appears under installation
The gas sensors in CO alarms have a limited and indeterminable life span, typically two to five years. The test button on a CO alarm only tests the battery and circuitry not the sensor. CO alarms should be tested with an external source of calibrated test gas, as recommended by the latest version of NFPA 720. Alarms over five years old should be replaced but they should be checked on installation and at least annually during the manufacturers warranty period.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Vacuums
Diagnosing the problem with my bissell quicksteamer plus upright
Was the exposed copper wiring on the electrical cord? If is then replace the cord. The main problem with this model is that Bissell obsoleted it as well as parts for it. But if all you need is a cord, you should be able to get one from a repair shop.
Mar 07, 2008 | Bissell 1960-3 QuickSteamer Plus Upright...
Vacuums Logo
1,756 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
