Question about Cycling
How do I adjust the tilt of the seat? Do I need a special tool?
  • 30 Answers
You only need on tool which is allen wrench.
Posted on Apr 11, 2011
How do you adjust the seat on a Trek Jet 20?
Should be much the same as with any bike. Loosen the bolt (probably metric allen wrench head) that is on the clamp at the top of the seat post, raise or lower the seat, and then retighten. If you want to move the saddle forward or back or tilt it differently you loosen the nut or nuts on either side of the saddle, move as desired, and then retighten.
Jun 13, 2016 | Trek Jet 20
Owner manual
under the seat there is a clamp, loosen it... and the seat will tilt
Jun 21, 2013 | Raleigh USA Bicycle Company Retroglide 7
No reverse after i park my 1962 ford automatic
Fluid level and a dirty filter are the first things to check, then a band adjustment is next on the list. as the pan needs to come off to change the filter adjst the bands at the same time. the tea levels in the bottom of the oil pan will tell you in there are more serious issues inside.
Terry
Nov 25, 2012 | Cars & Trucks
How do I adjust the tilt of the saddle?
It depends on seat post. If you have adjustable seat post, you should be able to tilt your saddle as needed when clamp screw(s) is loosened.
Jun 01, 2011 | Fizik Arione Wing Flex
How do you adjust the carbuerator
Most of the new carburetors have screws with special heads that do not accept tools most DIY's will have. These carb. adjusting tools are restricted to dealers only. I can't speak for all dealers but many will adjust the carb. for you if you ask.
If you can adjust yours, start with one turn out from "seat" and adjust as needed for proper performance.
Feb 12, 2011 | Poulan 25CC Gas BlowerVac
Shock adjustment on sportster 50th anniversary model
The shocks are adjustable for preload. You need a special tool to set them with. The bottom spring seat turns.
Aug 08, 2010 | 2003 Harley Davidson XL 1200 C Sportster...
How do I deactivate the easy-access/easy-entry seat feature on a 2003 Lincoln LS that is not equipped with the vehicle message center?
If you do deactivate it.you will loose the Seat,Pedal Adjustment,Outside Mirrors,Tilt/Telescope. So I would leave it. What are the issues?? If you have the owners manual it is on page 146. I checked the service manual and you may be able to remove the seat settings,in the seat driver module. You would need a scan tool. That I guess is why the owners manual mentions the dealer can turn it off. My question is ,that there is no manual seat adjustment?
May 02, 2010 | 2003 Lincoln LS
Compressing the rear disc brake caliper on 2008 grand caravan
The rear calipers on these models require a special tool that compresses and turns the piston in at the same time -- most parts stores carry this tool.
It is called a caliper piston press -- and it installs where the pads would go and acts like a c-clamp,when turning handle it will turn the caliper piston backinto the caliper as it compresses it.
Anytime the brake rotor or brake pads are being replaced, the rear caliper piston must be seated (bottomed) to compensate for the new brake rotor or lining. Because the Parking Brake self-adjuster mechanism is attached to the piston, a special seating method is required. The only acceptable method is by rotating the piston back into the bore using Retractor,MILLER Special Tool 8807, . Any other seating method will damage the self-adjuster mechanism.
Good luck and hope this helps.
Mar 07, 2010 | Dodge Caravan Cars & Trucks
I just purchased a 2007 jeep liberty sport
I have a 2005 Jeep Liberty and the smae lever that tilts the seat also moves it forward and back. Press forward or back on the switch. Also check for blown fuse or a loose wiring connector under the drivers seat. Good luck, Techjoel
Jun 07, 2009 | 2007 Jeep Liberty Sport
Explorer seat
You need a new or used passenger seat tilt lever. Mine broke also. There are a couple on sale on EBay for $30.00. See link, otherwise you can buy new from Ford for about $75.00.
http://cgi.ebay.com/ebaymotors/FORD-EXPLORER-DRIVER-SEAT-TILT-LEVER-ASSEMBLY-91-94-OEM_W0QQcmdZViewItemQQcategoryZ33701QQihZ023QQitemZ360071362943QQrdZ1QQsspagenameZWDVW
Jun 28, 2008 | 1997 Ford Explorer AWD
Cycling Logo
185 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
