I have a reddy heater rlp30 propane forced heater 30,000 btu. Heater lights ok but will not stay running unless i hold red bypass in, when i let go the heater goes out. Do i need a thermocouple or something else? Can you help
    Brigadier General:
  • 4,736 Answers
Achowe - Several things can cause what you have described.
Restricted air flow. Check the heater's inlet & for any obstructions.
Damage Fan - check the fan for any obvious damage.
Excessive dust or debris inside the heater or in the surrounding area.
To help you more, I am including a link to the Owners Manual for your heater. You can download and print it for future reference. If you find you need to order parts, they can be found online at Master Distributors. They stock all the parts for DESA/Reddy Heaters.
http://www.desatech.com/manuals/Construction%20Heaters/BLP42A.pdf
Hope this helps you solve your heater problem.
Posted on Apr 10, 2011
Testimonial: "ecellent feedback and very fast thanks for the info "
  • Rich Landrum Apr 10, 2011
    My pleasure. And thank you for the 4-Thumbs Up rating.
Have an rlp30 reddy heater, have spark and gas but will not light.
wile red button is pushed no flame or turns off when the button is released the flame dies ? if no flame tank is too small or spark isn't in far enough to catch gas . if flame is present with button down then the over heat switch on the in line thermal coupler could b bad u can check the over heat switch with a jumper between the two wires and if it stays lit you got it if it goes out then its the thermal coupler that's bad
Dec 12, 2013 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Rlp35 reddy heater runs few minutes flames out, fan continues to run?
clean the sensor so that the control can have confirmation of ignition
Nov 11, 2012 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My heater won't stay running
if you get heat when it runs and then it shuts downs you need to clean your flame rod or replace the thermocouple if its a pilot lit furnace
Feb 06, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Heater will not stay lit after releasing button
Make sure your thermocouple tip is in the pilot flame and the other end is snuggly screwed into the control. Clean the pilot if not heating thermocouple. If pilot is heating tip thermocouple and it still goes out after holding the button down for 2 minutes, then your thermocouple is likely bad.
Jan 22, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Feb 06, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
410 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
