Question about Whirlpool Washing Machines
I have a whirlpool AWM 1250 it is about 2 trs old Today I used it with no problams, however, I did hear a few Clicks during the cycle. This evening I tried to use it again but it refused to obay all comands I selected several combinations in an attempt to gre it going It will only make a noison 4 (DRAIN). I have done all the obvious i.e.checked and cleaned at the bottom filter doo, and made sure there was a supply of water and of courst power on. Kind Regards Mrs Eunice doyle
  • 1314 Answers
SOURCE: UL Code
if you have cleared the codes by pressing pause/cancel and the codes keep setting call for service your still under warrenty let them deal with it
Posted on Jan 12, 2008
hemantraj
  • 638 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
the problem is solved in this link
www.applianceaid.com
Posted on Aug 29, 2008
MNTECH
  • 1543 Answers
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
You will need to replace the drain pump motor. The pump impeller has separated from the motor shaft. You can push it back on, but it will just come off again. I have not tried adding adhesive because I didn't want a call back. That may work if you want to try it. To replace pump motor:
Take the rectangular recess out by using a putty knife on the left or right side, Remove phillips screws mounting pump. Pull machine forward about two feet to allow you to tilt the machine back to lean it against the wall. Reach under to access the pump. It is held in place by a plastic tab you can depress to remove, but if you break the tab, don't worry, as the mounting screws will hold your pump in place just fine when reinstalled. Remove pump by disconnecting hoses and electrical plug. Change out pump motor (three phillips head screws)
Posted on Nov 16, 2008
  • 5 Answers
SOURCE: Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
Posted on Mar 05, 2009
MNTECH
  • 1543 Answers
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Posted on Apr 04, 2009
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 8143 doesn't stop at the end of the spin cycle. Instead it clicks for a while when the timer displays 1 minute then displays F07 then goes back to wash cycle. While googling I found something...
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2010 | Whirlpool AWM8123 Front Load Washer
Whirlpool awm 221 washer
you will need a replacement heating element for the appliance
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal De
