Question about NEC MultiSync VT590 LCD Projector
I have a nec vt590 projector.When you watch a movie. A big spot appears in the center of the screen. I believe one of the three lcd panels that is attached to the lense has overheated and is distorting the image. can these [p-si lcd panels] be replaceby the end user? if so do you know where to purchase. thank you john john@hootersonline.net
  • 442 Answers
If it is a bluish colour then the organic polarizer plate that allows the blue light to pass through it to the blue lcd panel is burnt due to old age.
If the spot is made up of pixel shaped spots rather than a blurred area, then perhaps the lcd panel is faulty, but this is less frequently the case.
You could disconnect the power cable and remove the cover and look at the optics parts to check where any overheated parts can be found.
Then you can be certain which bits to replace.
Another option is to buy a faulty VT590 unit off ebay for a fraction of the price and have a go at swapping the parts between the units.
The lcd panels can be removed and replaced, but require precision alignment and you need the extender cables to be able to do it successfully. So give that a miss, replace the whole lcd prism assembly as one item.
Hope this helps.
Posted on Apr 11, 2011
Lamp not glown, how check lamp is faulty or ok
These use a high voltage discharge bulb and there is no easy way to test them. The power ballast could be tested but that takes a special meter.
Oct 16, 2015 | NEC MultiSync VT590 LCD Projector
I have a NEC projector in my class but projects white spots on the screen which are multiplying day by day. Has anybody solved this problem ???
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 07, 2014 | NEC NP200 Projector
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
When on "computer" mode I
disconnect the cable at the projector end and plug into a monitor to check that the video signal is enabled on the cable. If it is then reconnect to the projector and select a lower resolution on the pc screen setting. See if anything appears on the projector
Aug 24, 2011 | NEC MultiSync VT590 LCD Projector
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
LCD VGA Display goes on and off.
Check refresh rate and setting for external display output. It won't work with unsuitable screen resolution, color depth or refresh rate. Check all three points and I believe you can troubleshoot the problem this way.
Jun 02, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Black dot appears in middle of screen when watching a movie
we changed out the light buld... now it works fine.. funny thing was projector was brand new just out of box... you could see first thing there was a brown spot in the center of the buld creating the spot apparently after it heated up.... thanks again
Aug 05, 2009 | Sharper Image 1617293 Projector
Nec projector vt590 doesn't project RED
Red, Green, and Blue signals come from different wires in the VGA cable.  This sometimes happens if a cable simply is not connected fully.  But it will also happen if the cable is damaged.  The damage might be visible in the form of a bent, broken, or missing pin.  Or it might be internal to the cable.
Try another cable.
If that's not it, then the connector on either your computer or on the projector itself might be damaged.
Also try another computer.
Components inside the projector could also fail.  But I'd bet on a cable problem any day.
Nov 24, 2008 | NEC (MTLAMP820/1020) Projector Lamp for...
NEC MultiSync VT590 LCD Projector Logo
204 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
