I seem to have incompability issues with my motherboard meaning i cant run win7 onmy comp only winxp i get blue screen of deat saying IRQ lees or not equal message every once and a while!!! My motherboard is p55-cd53/ p55-cd45 MSI ...Have you ever hear of such problems with my motherboard... At store where i bought my comp they said they changed every component hard drive power suply graphic adapter even moterboard...and so on i had my comp 4 times on repair and still i cant run win7 normally without restarting or freezing randomly without any pattern can u help me with some advice...tnks....Eugen Jerkunica Split Croatia...
  • 64 Answers
Just go for a lower version of windows.i think that is the only solution to the problem
Posted on Apr 10, 2011
Run only win 98.get's blue screen when trying to install win xp,vista on win7
you get this message when there is some hardware which is incompatible or fails / crashes during the installation of OS since you have tried a different hard disk already it cannot be that so try with a different Ram or update bios / replace motherboard.
Feb 10, 2012 | Abit Computers & Internet
Asus eee box eb1501p I've got a problem with Win7 so i've deleted the partition on wich was win7 and i've installed winxp. At the first startup of winxp i've had the blue screen error and when i restart...
If you have deleted the Win7 partition then you will require a Win7 disc to start up and repair the system with.
Win XP will not run on this type of machine as there are no drivers for the VGA or main board.
Feb 24, 2011 | ASUS Eee Box EB1501P-B016E Nettop PC -...
Hi, Hope you can help. I've just fitted a new motherboard to my computer (ASUS crosshair 2 formula). My memory is 2 x 2GB DDR2 running at 800Mhz. Th machine will run fine using either of the sticks, but...
Hi. Asus has a great utility that lets you update your bios even in Windows.
http://www.asus.com/product.aspx?P_ID=EIDxaW1Ln3YR9RA2
At the download section select your OS and in Utility section find "ASUS Update V7.14.01 Install Program" This program will automatically update your bios.
As for your Ram issue. Did you try each stick in each ram slots ? If you did and saw no issues, then I am only suspescting of incompability between your Rams.
Oct 12, 2010 | ASUS CROSSHAIR Motherboard
I am running win 7 & when tried to install xp its showing compatibility problem . pl reply
Remember.... the OS compatibility is only lower to upper...not upper to lower....i.e.....
Win7 is higher than WinXP....so u cant run / install WinXP using Win7...but u can do the otherway round....i.e...1st u can install WinXP in C: drive, then let the machine start, once u get to WinXp dekstop then install Win7 in D: drive...(it's called Dual Boot)...so on the boot screen u can choose which OS to work with when the PC starts....
all the best
pls revert back...and kindly leave a rating and feedback to this solution...it will help me become a "Guru" here on Fixya....
regards...
Sep 29, 2010 | Computers & Internet
Can I upgrade the drivers for this board to run win 7 64 bit
no drivers are available from any mfg of any hardware....all of the drivers have been given to MS by all mfgs.....
so if u r runing win7...then i am sorry MS will first validate ur Win7 for genuine OS...then only they will alow u to get the correct driver for any HW....
so contact MS for any driver for you PC....else do as i do...
have dual boot ...
C: for WinXP
D: for Win7....
so any activity that i cant do in win7 i fall back on XP to do...
Sep 27, 2010 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
I can't load Windows XP. Get this error with BLUE SCREEN of DEATH IRQL_NOT_LESS_OR_EQUAL I had windows 7 on it but not all of my devices would work. Win-7 loaded with no problem . So I put XP in format and...
Good day!That error used to be a non compatible with the hardware.I don't know this board,but i'll based my idea on your trouble..Mostly new hardwares today don't accept XP OS..Try to look the Motherboard's features..see if it is compatible with XP..
Ask me if you still don't get what I mean..
mastergani
Mar 21, 2010 | Intel DP45SG Motherboard
Cant detect MSI 661FM3-V LAN driver for win7
eventually through continued research, i found out that this is a common issue with several mobo ang win7... SIS driver for LAN was the answer. i just downloaded the driver then install manually. although there is still no driver support intended for win7 as of the moment, vista driver does the trick...
Feb 01, 2010 | MSI 661FM3-V Motherboard
The machine frozen only at reboot
it seems to be a hardware issue.
to find out whether the bios or the handling of components is causing trouble, do as follows
when booting up, press pause-button after video-card and RAM check,
right when the system components are being listed(screen will halt)
now look if two or more components(like network card, IDE-controllers)
are using the same IRQ.
If so this could be your problem, because then internal handling on the hardware side fails.
to fix it, enter bios(press F1 orF2 orDEL during booting), set all the IRQ
handling to auto mode and if there is an potion available: plug and play operation system, then disable it.
Now the BIOS manages all components, not windows(it has the capability, though)
now boot up and in windows left-click start, goto: settings - control panel - add/remove hardware - hardware wizard
run the wiz and if it does not find any problems u did it.
good luck
Aug 09, 2009 | EliteGroup ECS EZ-Buddie EZ-D1V7-2 Socket...
Cant download railraod tycoon 3
AMY-That used to happen to me. Is it a blue error screen? If so, the comp motherboards dying. If not, try reinstalling the game.
Jul 11, 2008 | Video Game Consoles & Games
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
