Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
I have ingersall rand com. one stage 5 hp. 60 gallon tank gauge outside at tank reads 40 p,s,i inside garage reads 40 p,s,i compressor keeps running will not build any more air. nothing has been messed with. thanks
    Novelist:
  • 205 Answers
You probably have some bad valves in the HP side.
Posted on Apr 12, 2011
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
I did not drain the tank on my 80 gal comp now trying to drain I only get a trickle out of the drain line. Help
Take drain plug completely out of bottom of the tank and remove the outlet plug on the side of tank. pour 1 gallon of clean water into tank and stir up sediment. . Replace the side plug and start compressor , keep this up until drain water runs clear not orange. Then re install everything and check tank pressure and for leaks.
Apr 15, 2013 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
I have a ingersall rand 2475e compressor that the valve that the small copper tube goes to started leaking. replaced the valve and put back together and now pop off valve on the line from the compressor to...
Sound like a bad receiver tank check valve. Located in top of the tank and the pop off valve is screwed into it. If check valve is good you need to remove the heads and check the finger valves. I believe you'll find your problem in the check valve
Sep 12, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
What size breaker for 5hp motor? Ingersoll Rand T30 242-5d 1988
If its a 220vlt compressor a 60 amp twin breaker is recommended. good luck!
Aug 08, 2011 | Ingersoll Rand Compressors 5-HP,...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
I have an Ingersoll Rand compressor (RA5E6VA) 5 HP 60 gal vertical tank (only found 3 HP listing below, but it says 5 HP on it) There is a plastic tube between where the pump attaches to the tank (air in)...
that is just a compression fitting. Sometimes just replacing the tubing is enough to get a bit on it. If not you should be able to get another fitting from an indstrial supplier.
Mar 06, 2010 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
I have an Ingersoll Rand 80 gallon, 5 hp compressor. The motor recently burned up and I replaced it with a new one about 1 1/2 weeks ago. The new motor now has burned up also. Could there be a problem with...
Yes it could be running (turning) hard which will make the motor pull high amps. If you installa new motor make sure to check the amps while running to be sure that the draw is not over the name plate spec. Could also be that you just got a bad motor... believe me it happens more often then you would think...
I am assuming that you have checked the oil in the compressor and that the level is okay...
Heatman101
Feb 26, 2010 | Ingersoll Rand Compressors 5-HP,...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
139 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
