Question about Ducane Affinity 3100
I bought the Ducane Affinity 3100 from Ace Hardware in 2009. The paint on the inside of the grill lid has started to bubble, peel and fall off. Is this covered by the manufactory warranty. Is it still safe to use? Thanks for your help in this matter.
    Brigadier General:
  • 4,736 Answers
According to the Owners Manual for your and the reading of the Warranty, No the paint flaking under the grill hood is not covered under warranty (see link below). As far as safety of using it is concerned ... only if you clean all the flaking paint and any residue, and repaint it with High Heat Grill Paint. This should only be applied after all greasy residue has been removed and only in light coats. Several light coats, in fact. It should be allowed to thoroughly dry between each coat, before applying the next coat. Once the final coat is applied, wait at least five days before using the grill. Be sure no paint gets down of the cooking grates or the burners. You can get the High Heat Grill Paint , form the same Ace Hardware store you bought the grill from. I believe Ace carries Krylon, which is one of the best High Heat Paints.
Posted on Apr 10, 2011
  • Rich Landrum Apr 10, 2011
    Link to your owners manual
    http://www.weber.com/help/manuals/ducane...
    Copy and paste it into your web browser.
The users manual arrived with the product but there are no user instructions and aswell as direct grilling I want to use the grill to cook joints etc. What setting do you use for indirect grilling and Is...
Direct Grilling is putting the items you're grilling directly over the burner(s) . Indirect Grilling is preheating the grill, turning off one or two burners and place the food over the burners that are OFF. In direct grilling requires cooking with the lid closed.
For more info on using a gas grill, as well as recipes got to the following link.
http://www.barbecuen.com/begin-gs.htm#axzz1SkGNJ9p8
Happy Grilling!!
Jul 21, 2011 | Ducane Affinity 3100
No instructions for assembly or use. Can you provide them?
Here's a link to your Owner's Manual. It covers the 3100 & the 4100.
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3100_4100_LP_OwnersManual_27010331_101508.pdf
Hope you make it in time for The 4th. Happy Grilling!!
Jul 03, 2011 | Ducane Affinity 3100
One burner wont light of the 3
Is the igniter not sparking or is gas not getting to that burner? Have you tried to match light that burner? Those three things is where you start troubleshooting the problem
If the igniter is not sparking, it could be that the igniter is covered with cooking grease or the wire to the igniter has come loose either at the igniter or the igniter module. And simply needs to be reattached (pushed back on).
If the burner won't match light, than it's not getting gas and should be removed and thoroughly cleaned. And while you're at it, remove and clean all the burners and the venturis valves.
Removing the buner burners on a Ducane grill is a bit of a task, so I have included a link to your Owners Manual to assist you. Pay particular attention to the section Annual Maintenance, starting on page # 28.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
May 10, 2011 | Ducane Affinity 3100
Bought this product but there is no assembly instructions or owners manual in the box is there a place to view it online?
Here's a link where you can download free Ducane manuals. Hope they have your model listed. Douglas
http://outdoorcooking.manualsonline.com/manuals/mfg/ducane/ducane_gas_grill_product_list.html
May 14, 2010 | Ducane "Affinity 4400" Propane Grill
Ducane stainless steel NG BBQ with uneven heat front to back
all grills are hotter in the back than the front even if you bought a grill that was 6000.00 it will do the same thing
Jul 26, 2009 | Ducane Affinity 3100
Paint inside lid peeling off when I cook
From Weber.com Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Apr 25, 2009 | Weber Genesis Silver C Grill
No assembly instructions to build the bbq
Go here to get manual.
http://www.ducane.com/manuals/
Good Luck and Please Rate FixYa!
Mar 21, 2009 | Ducane Affinity 3100
Paint on top inside of lid is peeling off.
Remove the paint. The heat will dry the metal and grease from cooking will keep it from rusting, if it's iron. If it's aluminum it's not a problem.
Mar 14, 2009 | Weber Genesis Silver B Grill
Can i run gas bottle inside the unit
Yes, it was designed for use that way, assuming there are no leaks, check with soapy water.
Sep 10, 2008 | Ducane Affinity 3100
Connecting to natural gas line
The city where I live requires a licensed plumber to do this. So I guess my problem is solved.
Jul 25, 2008 | Ducane Affinity 3100
Ducane Affinity 3100 Logo
315 people viewed this question
Top Ducane Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
