Question about Fedders AED24E7F Wall/Window Air Conditioner
Fedders PTAC/PTHP Condenser Fan
Need a condenser fan for a Fedders PTAC/PTHP. Have been unable to find one through Fedders or Repair Clinic. Help!!
  • Anonymous Sep 30, 2008
    My PTAC was purchase in March 08 and the AC turn on for about 5 min. and them turn off. Someone told me I need a control card. I am unable to contact Fedders because they are under Charpter 13. At this point where can I found a control card and where is it located at in the unit.
    Model # A6PTHP15UW7A
    Serial # FV161725173X
    I live in Virginia Beach area.
    HELP.
Greg,
The model # is A6PTHP15UW7A (Fedders PTAC/PTHP), but after posting our "help" comment, we found the part (#2439845) through the RepairClinic, and they will send it to us.
Thank you for your attention to our dilemma!
Posted on Aug 09, 2008
    Problem Solver:
  • 8 Answers
What is your model number, maybe we can help.
Greg
Posted on Aug 07, 2008
Condenser fan on heat pump does not turn off
If it is just the condenser fan that means you have a fan relay that has welded shut. Turn power off to your unit and trace the wires from your condenser fan back into the control panel at the unit. You'll have 3 wires going to it. 2 go to the run capacitor and one goes to the fan relay. The one that goes to the fan relay is the part that needs to be replaced. If you have no fan relay and it goes to the main contractor, half of your main contractor is welded shut and will need to be replaced.
Sep 18, 2014 | Carrier 52PQ-515---3 Premier Series Heat...
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Condenser fan does not come up to full speed.
These Ptac units are advance system that are designed with variable speed motors that modulate in order to save energy, This is normal operation, because starting a motor at a lower speed rather than the conventional high speed will save energy, which translates to saving you money. As the load increases (heat) on the condenser coil, the fan will ramp up accordingly.
Aug 02, 2013 | LG LS-K2430HL Heat Cool Mini Split Air...
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
The condenser fan blew out and damaged my radiator on a 2005 civic ex. The car is over heating and as the temperature needle goes up the radiator fan does not move. It only moves if I put the air on and...
hi
1st u have to replace condenser fan and radiator assy , it will solve your problem , cause due to no coolant radiator fan is not working and cause of engine overheating a/c system got trip . replace both condenser fan and radiator and put new coolant. thanks.
Mar 29, 2010 | 2005 Honda Civic
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
TRANE PTAC
You need to replace your control board, but if you are can repair it by your self you can change the relay that supply the fan and condenser.
Nov 15, 2007 | Heating & Cooling
Fedders AED24E7F Wall/Window Air Conditioner Logo
648 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
