Question about Health & Beauty
When battery connected it runs automaticly without using throttle so i have no control and must disconnect battery
  • 692 Answers
Choose you have a bad throttle pot and need to have it replaced aThe provider wjere you got your scooter should be able to get the part and repair it or you can replace it yourself Hope this helps
Posted on Apr 11, 2011
I have a 2001 f650 GS. When connected to the battery the engine will start automatically without turning the ignition on.
Hi Raymond remove the starter and power it up direct it could be the solonide sticking. Regards Jim...
May 08, 2015 | 2001 BMW F 650 GS
1998 corolla dies when idling runs ok driving
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 06, 2012 | 1998 Toyota Corolla
96 suburban 7.4 low idle
Nov 02, 2012 | Cars & Trucks
Toyota traga engine cuts-out while braking
Nov 01, 2012 | Toyota Cars & Trucks
Hi i just replaced the air intake elbow from throttle body to air flow brand n ew and still the car wont idle
Try this.
Oct 26, 2012 | 1994 Mazda MX-6
I changed the engine oil, filter and spark plugs in my 1999 Volvo 940 (1996 cc). Upon starting up, the engine runs at lower rpm and "hiccups" at idling.
Engine stalls or RPM fluctuates at idle up and down.
Oct 15, 2012 | Cars & Trucks
93 lumina doesnt idle
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Sep 04, 2012 | Cars & Trucks
Where is throttle positioning sensor on a suzuki forenza
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the Intake Air Temperature (IAT) sensor connector.
  3. Disconnect the breather hose from the valve cover.
  4. Remove the air intake tube.
  5. Disconnect the throttle cables by opening the throttle and moving the cable through the release slot.
  6. Disconnect the vacuum hoses from the throttle body.
  7. Disconnect the Throttle Position (TP) sensor and the idle air control valve connectors.
  8. Disconnect the coolant hoses from the throttle body.
  9. Remove the throttle body and discard the gasket.
  10. Remove the TP sensor.
  11. Remove the Idle Air Control (IAC) valve.
  12. Remove the throttle body retaining nuts.
  13. Remove the throttle body.
To install:
  1. Install the throttle body.
  2. Connect the TP sensor connector and the IAC valve connector.
  3. Connect the coolant hoses to the throttle body.
  4. Connect the vacuum hoses to the throttle body.
  5. Connect the throttle cable.
  6. Install the air intake tube.
  7. Connect the breather hose to the valve cover.
  8. Connect the IAT sensor connector.
  9. Connect the negative battery cable.
  10. Fill the cooling system
  12. i hope this helps tps is attatched to hrottle body on other side than throttle cable
  13. plz dont forget to vote rep[ly if you need more help
Jan 17, 2011 | 2006 Suzuki Forenza
My car just randomly dies after i shift it from reverse to drive. its an automatic by the way.
Check for sludging in throttle body or bad idle air control. How are your ignition wires and spark plugs? Have you ever cleaned your injectors? Do you have any vacuum leaks? Is the check engine light on? Here is a possibility: disconnected your battery for 3 minutes, then connect and run for 2 minutes without touching throttle. This is called adaptive learning strategy.
Jul 07, 2009 | 1987 Ford Crown Victoria
1998 beetle throttle 2.0
the car's computer needs to relearn it's correct idle allow to run for several minutes and the computer's RAM will return and idle will be fine. On the automatic transmission it may take several miles of driving to shift normally as the computer learns and adapts. Loss of battery voltage can cause all sorts of running problems until this happens.
Mar 22, 2009 | 1998 Volkswagen Beetle
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
