Question about Garmin StreetPilot C330 GPS Receiver
Batterys how do you change the batterys
  • 1 more comment
  • bkeithezip Aug 09, 2008
    what tool do i need to change the battery on my c330 streetpilot
  • jjahoo Aug 30, 2008
    how do I change or check my gps c 330 battery because when I turn the car off the gps goes dead
  • droebuck Oct 03, 2008
    It will come on and then go off.
    Problem Solver:
  • 9 Answers
  1. Order a new battery. http://www.all-battery.com/ It was LG Li-Ion 18650 3.7V 2400 mAh Rechargeable Battery with Tabs. Original battery is 1,800 mAh so the replacement should last longer.
  2. Take the screen cover (faceplate) off and unscrew 4 screws. You will need small Philips head screwdriver.
  3. Pull off the front of the GPS. Be carefull with the GPS antenna. Make sure you remember its position so it is easier for you to assemble it later.
  4. Unscrew 2 small screws holding metal battery retainer strip. The battery is behind it. Pull battery out and disconnect it from the board.
  5. Cut the heat shrink tube the battery is in and de-solder the joint.
  6. Solder new battery. A small 15W soldering iron will do the job perfectly. Make sure not to overheat the battery.
  7. Insulate the solder joints.
  8. Put the new battery inside a heat shrink tube. You can get it from HomeDepot. It is ¾ inch diameter.
  9. Use a heat source (I used a gas lighter) to “shrink” the tube. Again be careful not to overheat the battery as it may explode.
  10. Put battery back into instrument and screw the metal band back onto the battery.
  11. Assemble everything back together.
*NOTE* Lithium Ion batterys do not take heat well. Leaving your GPS unit on the dash on hot sunny days will decrease its expected lifespan.
Posted on Jan 15, 2009
SOURCE:
Can i change in battery myself
You can, but it is best to keep the power connected as you do it so that the UCE and anti-theft doesn't get reset.
I used a trickle charger on the leads to keep 12 volts in the system. you can also do it with two lengths of wire.
How to change your car battery without losing your radio code and ...
z? 10:30 https://www.youtube.com/watch?v=9HREVVZAqNI
  1. Similar
Dec 10, 2011 - Uploaded by heymargaretlook remember positive first okay will video positive nine volts to a positive lead here into a negative lead here. it's ...
Charge your car battery without losing your settings! - YouTube
2q==? 5:23 https://www.youtube.com/watch?v=pQF7AfitpDw
  1. Similar
Nov 27, 2016 - Uploaded by someguyinncarolina ... radio/clock settings. I'm using a second car battery in this video, but you can also u... ... Charge your car ...
How to Change the Car Battery without losing the settings - YouTube
9k=? 3:31 https://www.youtube.com/watch?v=DNOzFtgbwss Nov 30, 2017 - Uploaded by Carlos Gonzalez How to Change the Car Battery without losing the settings.
bodgit and leggit garage how to change a battery without losing codes ...
9k=? 4:54 https://www.youtube.com/watch?v=dv6DwmJXWYw
  1. Similar
Sep 15, 2015 - Uploaded by bodgit and leggit garage bodgit and leggit garage how to change a battery without losing codes ... your car battery without losing ...
How to Change a Car Battery Safely
www.myautorepairadvice.com/change-a-car-battery.html
  1. Cached
  2. Similar
How to Change a Car Battery Safely. Connect a Memory Saver. To change a car battery without losing settings, you will need to connect a memory saver to your vehicle. Disconnect Battery Cables. Remove Old Car Battery. Clean Out Any Corrosion. Install New Car Battery
how to change car battery without losing settings Google Search
May 24, 2018 | Cars & Trucks
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How to change the battery onetouch glucometr
take old battery out, put new battery in. Most pharmacies stock the battery and would be happy to change it for you.
Dec 08, 2014 | Motorcycles
No low battery warning..
  1. Open Power Options by clicking the Start button, clicking Control Panel, clicking System and Security, and then clicking Power Options.
  2. On the Select a power plan page, next to the plan you want to change, click Change plan settings.
  3. On the Change settings for the plan page, click Change advanced power settings.
  4. On the Advanced settings tab, expand Battery, expand Low battery level, Reserve battery level, and Critical battery level. Change the percentage of battery remaining that you want for each level, and then click OK.
Oct 14, 2013 | Acer Computers & Internet
Changing the battery resets my date. is there another battery
your camera doesn't have internal battery so everytime you change the battery it will ask you to set the date...
Aug 17, 2009 | Kodak EasyShare Z712 Digital Camera
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Garmin StreetPilot C330 GPS Receiver Logo
401 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
