Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
My USB says 0 bytes used space and 0 bytes free space and it does not open how can I get my data from it
  • Verbatim Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Apr 10, 2011
Pen drive showing 0 byte
Do not use any more and get some data recovery freeware.
Sep 14, 2017 | Transcend (589307) Media
32gb SD card is showing 0 bytes used space and 0 bytes free space
Try formatting the card and be sure the locking switch is in the off position.
Sep 14, 2011 | Transcend (589307) Media
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
Nov 17, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
On opening a pen drive it is showing 'please insert a disk into removable disk (h:)' and opening its properties it is showing used space 0 bytes free space 0 bytes
Hello there yogeshpat876.
Here's your geek-steer ...
Is this a new drive? If so, it probably just needs to be formatted [and optionally assigned to whatever free drive (letter) you desire]:
Start > Run... > tpye "diskmgmt.msc" (without quotes), then OK
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Transcend (589307) Media
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
May 31, 2009 | Transcend (589307) Media
Usb flash drive corrupted
try other usb port, or other computer, if still have problem, download a usb recovery software, one I used before is Asoftech Data Recovery, you can follow this guide for usb recovery
usb file recovery guide
Oct 18, 2008 | Electronics - Others
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
849 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
