Question about Epson Stylus NX100 InkJet Printer
I have an Epson Stylus NX100, that worked fine about a month ago. I needed to get something printed off and when I attempted to print, the paper went through and it went through the motion of printing but nothing came out on the paper. I tried head/nozzle cleaning but that didn't work, my papers are coming out blank. I've read through the site and googled my issue, but nothing seems to be working. It's like one day it worked, next day nothing. I even checked all the connections. I was going to try to reinstall but my software disk seems to have gone MIA. Any help is appreciated! Thanks.
  • Epson Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Apr 10, 2011
I have a new laptop computer. It will recognize my epson nx100 printer, but it won't print.
Install Epson printer software from Disk if not disk then go to Epson website and locate your printer and download.
Mar 19, 2014 | Epson Stylus NX100 InkJet Printer
General Error message on a Epson Stylus NX100
Incase you have used a compatible cartridge , they may not work at times . Insert the old cartridge and check , if it prints ( even though partially ) . The problem could bein the cartrige or the fitting of the same .
Dec 20, 2012 | Epson Stylus NX100 Multifunction Printer...
My printer, an Epson Stylus NX100 does not print. I downloader a new printer driver without success. Lots of ink too.
You will have to go to the control panel and remove all the software with Epson then unplug the printer and then install with your orginal disk follow all the steps in the software install and dont plug the printer in until it ask you to this will reset everything and most likely you will be able to print
Jan 23, 2011 | Epson Stylus NX100 InkJet Printer
Change black ink and now prints with white lines through the words on every other line
It is CLOGGED print-heads that cause the ink to _not_ be sprayed onto the paper, resulting in "white" horizontal lines.
Run a "print-head-cleaning-cycle", using the Epson software installed when you installed the printer.
Aug 28, 2010 | Epson Stylus NX100 InkJet Printer
Printer says offline
Try to refresh the Print Queue. Go to System preferences then select Print and Fax. Highlight NX100 and click on the minus sign ( - ) to delete the printer. Re-add the printer by clicking on the plus sign ( + ).
Apr 10, 2010 | Epson Stylus NX100 InkJet Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
to flash, then release the buttons.
Cleaning the Print Head 21
4. Check the nozzle check pattern that prints to see if there are gaps in the lines.
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
I have an epson stylus nx100 printer but I can't seem to get the paper in the right spot so it will print. Where does it go?
***hi there,ill be willing to help you on that. ****
Load Paper for Documents
1. Open the paper support, then open the output tray and pull out the extension.
2. Flip the clear plastic feeder guard forward, then squeeze the edge guide and slide it left.
3. Insert paper, printable side up, against the right side and beneath the tab.
4. Slide the edge guide to the edge of the paper, but not so tight that the paper bows.
5. Flip the clear plastic feeder guard back.
Sep 17, 2009 | Epson Stylus NX100 InkJet Printer
Epson Stylus C88
my printer will not stop printing despite having been disconnected and turned off in an attempt to stop this from happening
Jan 13, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus NX100 InkJet Printer Logo
417 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
