Question about Amana DLG330RAW Gas Dryer
I have an Amana dlg 330 raw. The dryer lights initially then after about 2 minutes the gas goes out and the ignitor does not glow again. If I let it cool and turn it on 30 minutes later the same happens. If I dixconnect the power to the cycling thermostat the gas stays alight and keeps heating. The coils were replaced a few years ago along, what other tests can I do for the cycling thermostat? Thanks
    Top Expert:
  • Amana Master
  • 34,255 Answers
Check for a defective ignitor.
Posted on Jul 31, 2017
5 Suggested Answers
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
aasc
  • 1606 Answers
SOURCE: Amana dryer ignitor lights, sometimes gas catches,sometimes not
Replace the coils (2) on the burner valve .
Posted on Aug 01, 2009
SOURCE: I have an Amana gas dryerDLG330RAW that doesn't
I have, for the 2nd time in 2 years, replaced the gas valve coils on my Amana dryer. Usually, intermittent (inconsistent) heat or no heat is caused by bad gas valve coils. They are one of the most common parts to fail and cost between 35 and 40 dollars for a valve coil kit and are easy to replace yourself. Remove the front of the dryer (or the bottom front panel, in some cases) and locate the gas valve. It is near the front, in most cases. There is a plate, held with 2 bolts, holding the coils on top of the gas valve. Remove the bolts and the plate, disconnect the coil wires from each coil and slide the coils off. Then place the new coils on top, hook up the wires, replace the retainer plate, and you should be back in business. Take note of which coil sits on which part of the gas valve. On my dryer, one coil has a 2 prong connector, and the other has 3 prongs. This should make it easy to determine which is which.
Posted on Jun 04, 2010
richroth
  • 9472 Answers
SOURCE: How do I route the belt on an Amana DLG 330 RAW
Here is the belt diagram you requested.
Posted on Feb 04, 2011
I have a GE gas dryer DBVH512GF1WW. The heat is inconsistent. I noticed the ignitor glowing and then a flame shortly after on the initial time I turned the dryer on. Then after the flame going out after...
sounds like bad gas coils located on top of the gas valve,when the coils start to fail the ignitor will glow,the coils let the gas in until the coils heat up and then ignitor glows but no gas.when the coils cool down they might work again for a short time until they heat up and fail again.if the flame lights and goes out after like 30 seconds and goes out and keeps doing this you have a block either in the dryer or the vent line but it sounds like you have bad gas coils.unplug the dryer,get at the valve,pull off the wires going to the coils and check them with a meter,one should be open,just remove the two phillips screws pull off the cover and slide the coils up off of the posts,unplug them and put the new coils on,you'll see like a little piece of plastic on the top of the coils,this fits intoo the cover so they line up correctly and holds them in place,also on the larger coil there's a spacer on the post,if you don't see it look inside the old coil,poke out the spacer and slide it onto the post and then install the coil.
Oct 23, 2013 | GE Dryers
Ignitor glows gas valve opens, burns for a while then gas valve closes and ignitor cycles , if dryer is off a while it will light again. amana
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 24, 2010 | Amana Dryers
The ignitor glows, the gas comes in, it lights then goes out!
heatman101
Sep 14, 2010 | Amana DLG330RAW Gas Dryer
I have an Amana dryer Mod. ALG649RAW. Turn dryer on ignites than flames, but after a few minutes goes out, it will again ignite, but won't flame. Is it overheating? The dryer is vented underground about...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 28, 2010 | Amana Dryers
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Amana DLG330RAW Gas Dryer Logo
178 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
