Question about Cosmi Print Perfect Platinum
I have print perfect platinum version 9.3.148. i had it on Windows xp and everything worked fine. I installed it on a new computer with Windows 7. When I try to add art from gallery to a project I get and error message (Control "has no parent window.) I cannot acess any graphics from the disk.
5 Suggested Answers
SOURCE: I can't get Print Perfect Platinum DVD to install
it start to install but quit before finish
Posted on Jan 10, 2009
jaghaglee
SOURCE: Broderbund ClickArt cds not work'g w/Printmaster Platinum 17
Contacted Fixya's Support Team (Premium Service). Their proposed solution: be sure to install (copy) the other ClickArt CD art files into the same Art Gallery file folder as PM Plat 17. Have not tried it yet, but makes sense that it would work. Thanks for your help - Fixya later!!
Posted on Mar 20, 2009
taran_2005
  • 10515 Answers
SOURCE: I have Perfect greeting card maker (CDRS789D1) and
Unfortunately, this product cannot be used with Windows 7. I had a talk with customer service and they said, they are not even planning to even introduce a patch that could make this product compatible with Windows 7.
The only option would be either to stick with operating system such as Windows XP or 2000 or 98SE for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 04, 2010
paljeet_serv
  • 29 Answers
SOURCE: Cannot load print perfect platinum
Find the program on your desktop
Right click and go to Properties
Click on the Compatibility tab
Check the Run this program in compatibility mode for:
Click on the drop down menu and select Windows Vista
Click OK
when you're finished
Posted on Aug 25, 2011
I have Printmaster Platinum 17 on my computer. It has stopped coming up and will not reload. Is there a site where I can download it again? Maybe directly from the internet?
Lest's star by telling you neither me nor FIXYA had ever released any version of Printmaster Platinum 17. OK? So, if you want to contact authors of this sofware, ENCORE SOFTWARE
Encore Official Site Download Top Software Hoyle Card Games The Print Shop...
Now, HAVING SAID THIS, dd you use ever Printmaster Platinum 17 with Windows 7? I understand that it is for Windows XP.
I'm no sure what kind of a mess you made with it uninstalling or removing but well, try to reinstall your original SETUP version in Windows XP COMPATIBLITY MODE
Befor you instal it cricght click setuo, select Properties, click on tab Comatibility and select option Windows XP Comatibility mode
If won'r work, I find no way to help you,
May 27, 2015 | Computers & Internet
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I have Printmaster Platinum 15 installed in an older computer (xp) and can convert a file to PDF. I installed it in a newer one (Windows 7) and cannot convert to PDF. I get something that says "Unable...
download pdf995 onto windows 7
http://www.pdf995.com/
it will install there are two files you have to install
once installed it will look like a printer to your program and then print to the pdf995 printer and it will convert whatever you print into a pdf file.
Nov 27, 2017 | Broderbund PrintMaster Platinum 15 Full...
Running Windows 7 and can't use my Photosuite 7 Platinum
Unfortunately Photosuite 7 is not compatible with Windows 7. It was supported for Windows 2000 and XP.
You can upgrade to the latest Roxio product, http://www.roxio.com/enu/products/allproducts.html?rTrack=m_pro_all . I think you need the Creator 2011. (Creator 2010 is also WIndows 7 compatible with the installation of a patch from Roxio.)
If you have Windows7 32-bit (click Start > Control Panel > System and Security > System for the details), you can try using the compatibility mode. Right click on the installer and select Properties. Then choose the Compatibility Tab. Select Run as Compatible with XP (I am not certain which SP option is best - I know the initial release is listed as SP1). Then right click again on the installer and choose Run as Administrator. Then check if the program is running in the compatibility mode. This may not work (it will not work with the 64-bit version at all).
If you have the 64-bit version of the OS or if the compatibility mode fails, you need a work-around. Your option is to run a computer with an older version of Windows. This can be a virtual, dual-boot, or true second machine. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install your Photosuite Platinum software in the XP mode (as you would if it were a stand-alone machine). It will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also your printer can not be installed on both the real and virtual machines at the same time.
I hope this helps.
May 03, 2011 | Roxio PhotoSuite 7 Platinum for PC
New computer running Windows 7. Print Master Platinum will not open. Is there a fix? Ran fine with XP.
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and select the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website.
Jan 06, 2011 | Sierra Print Artist Platinum
Create a card 3 will not install in new computer with 64 bit windows 7 Please help i have your newer versions and this is my favorite
I have Createacard 3 installed an running on Win 7 64 bit - however - you have to install XP Mode first which is free from Microsoft if you have Win 7 Professional or Ultimate (not Home). I now have an icon on my desktop that I double click and Createacard 3 loads and works fine.
Dec 07, 2010 | Broderbund American Greetings Creatacard...
Why does print master platinum 18.1 which should be compatible with Windows 7 still not work
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jul 15, 2010 | Broderbund PrintMaster Platinum Version 18
Want to transfer Print Artist 4.0 Platinum by Sierra from old computer using Windows XP to new computer using Windows 7. Each effort results in a window appearing which states "Run-time error "5".
This simply means that your Print Artist program is no longer compatible with Windows 7. Some of the support files that used to work with XP is no longer recognized in Windows 7.
One way to resolve this is to contact or visit Print Artist's developer's website and search or ask for any windows 7 support or patches for your version 4.0
Jun 23, 2010 | Computers & Internet
Can i install the print master platinum 16 on my new computer with windows 7
ypu cannot use print master platinum 16 with windows 7 or for that matter vista
Mar 05, 2010 | Broderbund PrintMaster Platinum 16
Trouble Installing COSMI Perfect Accountant Platinum
I'm Working as a Technician! You can explain your problems to me by dialing my toll-free number +1 (844) 355-5111.
Regards
Jun 30, 2017 | Cosmi Perfect Accountant Platinum...
Cosmi Print Perfect Platinum Logo
89 people viewed this question
Top Cosmi Computers & Internet Experts
Alun Cox
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
