Question about Music
Hello I got a technics kn400 broken and i try to fix it... It does nothing when powered on... Does anybody have the service manual for this keyboard? Thanks in advance Akis
  • Music Master
  • 5,603 Answers
Check the power supplies... beyond something pretty simple you won't have much of a chance of fixing if it is on the main board. Technics is really out of the business for the most part... they are a part of Panasonic. Expect to find voltages of +5 and +/-15 volts.
You can download a service manual for a KN6000 here and just MAYBE find enough simularity:
http://elektrotanya.com/technics_sx-kn6000-sm.pdf/download.html
Scroll down to the "Get Manual" and click on it to start the download.
Posted on Apr 11, 2011
Testimonial: "Thanks for the manual and the help! It was a resistor used as fuse...! Thanks again!"
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
When I switched on the Piano the LCD screen illuminates but there is no text and nothing works.
TECHNICS Manuals
..technics owner manuals at link above ....some service manuals there too
Jul 03, 2015 | Music
Power module out
First of all measure the power output of the mains adaptor. If this is working and the polarity is correct proceed.
Plug into keyboard with a lifting movement on the plug on the end of the cable - does it turn on? If not try pushing down on the plug. Does it turn on? IF in either of these positions the socket has broken away from the PCB - you will need to resolder or fit a new socket.
If still a problem then you would need to investigate the power input lines on the board inside. If you are not technically minded probably best let to a Yamaha service centre.
Jun 15, 2015 | Yamaha P-85 Electronic Piano
The top keyboard of 3 keyboards work, but not the middle and bottom one. There is a distort sound on speaker if you press one of the keys on middle and bottom one. What can be the problem Please ....
I haven't actually got the means to trace out diagrams on this particular model but I did find you a service manual if you have the technical skills to fix it.
https://celedoniaorgan.netfirms.com/cos2/index.php?main_page=index&manufacturers_id=19
Mar 09, 2014 | Music
Keyboard does not turn on
Locate the fuse on the keyboard. Possibly blownout
May 15, 2013 | Casio WK3800DX 76 Key Digital Music...
Hello, I have a big problem with my korg pa800 , yesterday I was on gig, and suddenly the whole keyboard in the middle of playing got the distortion on every sampled or fabric tone!!! I have tried...
It will require repair. I suspect by you description that the D-A convertor has failed. This is a chip that is far beyond a DIY project to change. Do further testing to make sure the power supply voltages are correct and that headphone output sounds the same problem.
Here is your service manual: http://elektrotanya.com/korg_pa800_sm.pdf/download.html
Scroll down to "get manual" and click to download the manual. IGNORE other download links.
Aug 07, 2011 | Korg Pa800 Synthesizer
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Where can I download a user manual for the technics kn2000 keyboard
Try this link:http://service.us.panasonic.com/operman/findmanual.aspx?cat=ORG I hope this helps.
Oct 23, 2009 | Music
Casio CT-670 Tone Bank keyboard completely dead
How familiar are you with schematics? I've just found my CT-670, There where marker marks on the keys. I cleaned it up. I took it apart as one channels had no sound. I love this machine. I want to find a manual for it also schematics would be very helpful for me too.
I would suggest looking inside for burns on semiconductors. or loose soldering. I need to replace a chip that has no cross reference... that I've found yet... I think it's an amplifier but need to spend more time on it....
Mar 14, 2009 | Casio Music
Music Logo
252 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
