Question about Kenmore Washing Machines
Our Kenmore top loader is leaking from the bottom. I turned it over and all the hoses are water tight. The hoses connect to a white plastic gizmo which in turn connects to the motor. The water leaks from where the plastic gizmo connects to the motor. How do I fix this?
    President:
  • 3,113 Answers
This should help you. http://www.youtube.com/watch?v=ee_FoNQlSog
Posted on Apr 10, 2011
I have a Kenmore top load washing machine and it is dripping water inside. Do i need to replace a valve or a gasket?
Until you find out why it is dripping turn off the water behind the washer. Then I would go and search online typing in the browser search "Kenmore top load washing machine model no _____ leaking - what is causing this?" and hit enter. You will get lots of leads. I did a quick search just on Kenmore top load washer leaking and found this video.
Hope it helps.
Tami
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Mar 03, 2015 | Kenmore Washing Machines
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
Apr 19, 2017 | Kenmore 24732 Top Load Washer
Washer is leaking
sounds like you have a hose problem. are the hot and cold water hose connections tight? they may need new washers. if that is the problem turn off water valves,disconnect hoses and replace them with garden hose washers from any hardware store. re-tighten them snugly. just tight enough so they don't leak. if it only leaks while draining, replace the short hoses connected to the pump,located inside bottom of inside of washer.
Sep 16, 2010 | Kenmore 9781 Electric Laundry Center with...
5 year old wash machine leaks as the tub fills with water out the bottom somewhere. Hot and cold hoses are tight, drain hose is tight. This machine was just moved from one location to another. What could...
your tub seal between the top of the transmission and the wash tub, or the fill tube hose to the load size control may have a hole in it from the lower tub to the control panel on top
Oct 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Water is coming out of the bottom of the washing machine
Tip the machine back and remove the 2 clips holding on the drain pump. Remove the hoses. Then turn the pump over to where the motor shaft enters it. There will be signs of water leaking out of the pump. Your local parts store will have the pump instock.
Nov 22, 2008 | Kenmore 22422 Top Load Washer
How can I fix my Kenmore portable washer 100.49722990?
Most common cause for water leak
is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore washer leak
With the machine unplugged and EMPTY disconnect the water and waster water connection from the wall and tip it forward you should then be able to access the pump.  Check the hoses running to the pump. (usually white plastic with 2 large and 1 small hose running to it.. you can also just move it away from the wall with it completely connected and run it thru a cycle to see where it is leaking from.
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Washing Machines Logo
62 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
