Question about Whirlpool Washing Machines
How do you open the top on a Whirlpool Washer to change the lid switch?
  • Anonymous Mar 16, 2014
    whirlpool washer LSQ9549PW lid switch
  • 481 Answers
You have to take the case off. take out the two screws on the control panel. they should be on the base of either the front or the back of the control panel. the picture is of one that is in the back. How do you open the - e23f106.jpg
these clips release the entire case, so you will have full access to everything you want including the lid switch.
Posted on Aug 07, 2008
  • 5,911 Answers
Here ya go. Click on this link for step-by-step instructions:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you have further questions, please let me know. Hope this helps you.
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
How do I open the top of the washer to change out the lid lock part?
top/front of washer seperates by way of hidden clips. insert putty knife or butter knife between front seam of cabanet and top. about 2 inches from left side and 2 inches from right side push in and pull up on top. lid switch is located under top/front
Nov 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer fills and does the wash cycle then stops. doesnt rinse or spin
Most likely your lid switch is broken on the washer. I(t acts as a safety mechanism to stop the tub during spin should you open the lid.)
The switch is located under the top of the washer on the right side of the lid opening. It is activated by a plastic strike on the same side of the lid.
Jun 12, 2010 | Whirlpool LTE6234D Top Load Stacked...
My whirlpool top load washer won't drain and spin
This is likely to be a problem with the lid switch.the lid switch is activated by the lid stricker when you lower the lid.these machines will normally fill & wash without needing the lid closed but when it gets to spinning & draining the lid must be closed,so the machine is acting as though the lid is open.the lid has probably been dropped or slammed shut & this can break the lid switch from where it mounts with 2 phillips head screws.
May 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
May 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Lid Switch
hithanks for the question The lid switch is located under top on right side if you open the lid you will see a small plastic plunger on the lid this plunger is what activates the lid switch Thanks for your question hope thisanswers your question The appliance doc
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How to open washer to check and fix lid switch
the lid switch can be changed without removing from closet for sure,you can remove the angular access panel between the2 units youll see 2 brass clips holding the cabinet to the top, slide the entire top toward you to remove. its located under there. there may be 2 screws across the rear of main top holding down as well but yea pulling out will get you kn more access to any component
Mar 14, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal De
