Question about Pentair Minimax NT Heater
My Pentair NT heater goes on by itself the next day after running spa the night before. What can be done to fix this problem>?
  • adam hudson
    adam hudson Apr 11, 2011
    I have no idea what you are tying to ask here?
  • zookeeper685 Apr 11, 2011
    When we run our spa at night, we shut it down as usual when we are done. For some reason, the heater comes on by itself the next day. We have a Compool CP3400 pool/spa control system that we use to turn spa on and off.
  • 31 Answers
Depends on how you turn it on: At the heater itself or with an automation system. If its with an automation system than your problem is with it. I assume this is the case.
When you turn the spa off make sure you turn the heater off first and then wait a few minutes before turning off the spa pump.
Also, check your programming.
Posted on Apr 18, 2011
Pentair minimax nt propane heater is blowing black smoke
is heater installed in a shed? how many btu's is your heater. You need 1 square inch per 1000 btu's for combustion air opening. Lack of combustion air will cause heater to under fire and produce carbon dioxide
Mar 16, 2014 | Pentair Minimax NT Heater
Tip
ERR code
When a heater is showing the ERR in the display panel, this is what Pentair classifies as a "hard lock out". Basically, there is something wrong with the heater and needs to be serviced. There is no way to reset this code, since there is a malfunction within the heater itself.
on Jul 09, 2009 | Pentair Minimax NT Heater
I have a pentair minimax nt high altitude propane 4000000 btu in a commercial setting i run it 12 hrs a day is that too much?
Hope you are using lots of insulation. I have a bubble cover exposed during sunny days then put pool cover over at nite. Also have 4 x 8 ft Styrofoam pink insulation on top of the bubble cover. That costs $19 per sheet at Home Depot. 2" thick R 10.
Nov 07, 2010 | Pentair Minimax NT Heater
Error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
May 23, 2010 | Pentair Minimax NT Heater
Pentair pool heater reads HI
thermister needs to be replaced. follow small yellow wires off control board to front header and thats where the thermister goes
Jun 21, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
101 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
