Question about A-Data Technology Adata USB C802 8GB BLK RETAIL AC8028GRBB Drive Case
My 16GB usb flash drive is not working. it is shown on safety removal & device manage, but when i try to open it the please insert disc message appeard
  • 32,281 Answers
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Posted on Apr 10, 2011
The usb ports on my acer 5250-0650 do not work when a memory stick is installed.
Have the ports ever worked? Have you opened the computer icon to see if the flash drive is being detected- but maybe not auto-starting? Also, if a drive is inserted (Windows system), you ought to see the "safely remove hardware" icon appear on your taskbar, near the clock. Clicking on the icon ought to show you the drive by name & drive letter.
Lastly, right-click Computer>properties>device manager>expand disk drives>if your flash drive is shown here, highlight it & uninstall the device. Remove the flash drive, then reinsert it. Windows will reinstall the driver & this may allow it to recognize the drive again.
Let me know?
Cheers
Feb 25, 2015 | Acer Computers & Internet
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
Cannot use my cendyne 16 g usb flash
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps
May 16, 2012 | CenDyne 16GB USB 2.0 Flash Drive (Black)...
Please help me to fix my usb flash drive 16gb.when i inserted it its says 'WRITE PROTECTED" when im trying to format it give the same message.
Hi ,
Right click on my computer
and select manage
then select disk management After that you will see all your drives including flash drive.
Now right click on your flash drive and format it .
May 10, 2011 | Computers & Internet
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Apr 23, 2011 | Transcend (589307) Media
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
Apr 16, 2010 | Electronics - Others
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
"insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
Oct 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
16GB Flash Drive NTFS Formatting
what brand flash drive is this? some of the cruzer brand flash drives are partitioned to 2 drives. you may need to go to the manufacturers website and remove the partition with a 3rd party software. if it IS a cruzer, that software is on the larger of the two drives that show up when you insert the drive.
Jul 11, 2009 | Electronics - Others
My USB flashdrive cannot be opened
have you tried it on a different usb port? if that doesnt work you may also try it on a computer
Jul 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
A-Data Technology Adata USB C802 8GB BLK RETAIL  AC8028GRBB Drive Case Logo
573 people viewed this question
Top A-Data Technology Computers & Internet Experts
David Payne
David Payne
Are you an A-Data Technology Computer and Internet Expert? Answer questions, earn points and help others
