Question about Panasonic NN-S762 Microwave Oven
The microwave will only stay on for a few seconds then it cuts off . The clock and everything stays on
  • mickee111 Apr 12, 2011
    I tried that and it didn't work. I tried to reset it how the manual says ,the microwave will go for about 7 seconds and cut off. I checked the plug and circuit breaker and everything is fine with that. When i set it to make the beep sound it will beep until you try to use the microwave.I don't know I'm doing wrong it was working then it stopped could the wrong button been pushed and messed up everything?
  • 17,970 Answers
On any of the Panasonic Microwaves with an inverter, if your unit runs for a short time and then shuts off without heating the food, your problem will typically be in either the inverter or the magnetron. A trace signal is sent from the main timer circuit board through the inverter and then back to the main board. If the signal is interupted or there is a failure in the high voltage circuit, it will shut down the unit. The only way to repair the unit is to determine which part is bad, most commonly either the mag or the inverter, and replace it. There is no magic reset button, or anything you can do from the from the front of the unit.
Keep us updated.
Posted on Apr 12, 2011
    Genius:
  • 1,196 Answers
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Posted on Apr 10, 2011
Everything works on the microwave, the fan, the lights, the clock except it will not cook. You press start and it runs for a split second then cuts off. If you press popcorn it says error door open.
It sounds like a fuse. With the door fuse blown it will cause the microwave to not operate all all. It is a small thing to swap over. Its a bit like a car fuse. There will be a few different ones but all have a different purpose. Not sure if you are handy or a local electrical handyman can do the job.
Mar 16, 2014 | KitchenAid KHMS2050SSS Microwave Oven
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Our ge profile microwave only stays on for 5 seconds then cuts off.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-S762 Microwave Oven Logo
269 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
