Question about Memorex MP3226 Radio Boombox
Hello, I'll try you folks one more time. This Memorex CD player will intermittently play CD's. When it doesn't, the speed that the motor that turns the CD is either jerky or sounds like it turns and the CD is slipping and won't turn proper. It acts like the motor is either intermittent or electronic / servo control has an issue. What are your thoughts? Thanks, Ken.
  • kwitzel Apr 11, 2011
    thanks much. Ken.
    thanks....KW.
  • 5,370 Answers
The motor is got weak Got internally dirty.Its spinning, but getting blocked and due to this it gets **** and the cd slips.The motor has to be cleaned first.You can clean the motor with dry cloth or tissue and spray wd-40 spray in the motor.Let it remain there for few minutes, then re connect motor and other components and check.If there is rust got collected in motor then wd-40 spray will melt that rusted components and lube the motor and it should spin.But if this is not helping and still same problem, the motor has to be replaced.------------- This should help.Thanks.Helpmech.
Posted on Apr 10, 2011
My Memorex Karaoke machine model # MKS2420NBL worked fine until I changed the CD now it won't play and the display just shows 2 lines like there is no CD in it. What happened?
You changed the player CD or the lens of the player . if you replaced the lenses check whether you attached the white ribbon data cable probably. at the same time check out whether is worn out .....
Jan 25, 2015 | Memorex Audio Players & Recorders
Why won't a CD-RW disc play in my car CD player?
Some of the older cd players, car or otherwise, just aren't capable of recognizing CD-RW's. The player in my 10 year old Ford Mondeo doesn't, but the updated model player in the newer Mondeo does play CD-RW's.
Aug 25, 2012 | Memorex 700MB CD-RW 80 Media (50-pack...
Toshiba DVD SD73000KU will not recognize ANY disk
hi
have you been tried to clean the lazer lens with a cd lens cleaner. if doesn't work you can do with manual cleaning using a fiber cloth moist with alcohol damped gently the laser lens which may be dirty causing not to detect a disc. now if those tries still doesn't work your last option to make an adjustment on the speed settings of the drive motor. at the lower portion of the lens their is a trimmer adjustment, you can used a small flat head screw driver then try to adjust the trimmer just a little bit counter clock wise, make sure the player is unplugged for safety. then try to plugged it and turn on the player, insert now a cd and observed. if the motor doesn't rotating, removed then check if worn out, replaced a new one if needed.this will worked now.
hope this will helped thanks for consulting the fixya.
Dec 25, 2011 | Toshiba Televison & Video
Where is the power button?
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you with your question. You want to know where the power button is on the Memorex MD6451R Personal CD Player? Well to answer your question, the power button is Play/Pause button. Insert a CD into the compartment, close the top and press the Play/Pause button (whether on the CD player or the wired inline remote). I hope this turns on your CD player and thank you for choosing FixYa to answer your question. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 28, 2011 | Memorex MD6451R Personal CD Player
MY DVD PLAYER SAYS WROND DISC WHEN I TRY TO PLAY A DVD
Remove the dvd cover and clean the lens whith a cotton sprinkler softly.
Try play it again, if the trouble persist, watch that the disc is turning with good speed.
if the disc do not turn or it is turning slow, change the motor turn disc, in countermove change the pick up laser.
Feb 13, 2010 | Memorex MVD2042 DVD Player
Will not play a Memorex cd-rw
try again! burn an audio cd, but burn it at max 12x speed!!
Oct 28, 2009 | Tascam CD-RW4U CD Recorder
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
2002 JEEP [Wrangler] CD player will not play Nero burnt CD's
I had the same problem in my 1998 Jeep GC Limited. It has been a year and a half since I have played a burnt cd in my cd player. I researched everything possible and came to the conclusion that it was either the type of cd I was using (some cds with prints etc are hard for the laser inside the player to read) or the burning speed, and after many failed attempts, I still couldn't find a combination that would work. Then yesterday, my brother had a burnt cd he had made with his computer and we tried it just to see if it might work and it did! So, the brand of cd is Memorex, the type is CD-R, and they are 80min. worth of recording time. I purchased some of these cds at Hastings (although I'm sure they are avaliable wherever you purchase blank cds) and tried burning one in my laptop just to make sure it was going to work and it did! I burned the cd using windows media player and before I started the burn I went into 'burn options' and set the burning speed to the lowest possible. Hope this helps!
Dec 11, 2008 | Jeep AM/FM Cassette with CD Changer...
Memorex Dvd player gets stuck on HELLO screen randomly
well. i had the exact same problem but i unpluged it pluged it back in, same prob hello screen so how i fixed my problem i punched it an it shut off an went on standby an worked ever since..4 any of you with anger probs like me it mite work atleast it did for me lol
Sep 28, 2008 | Memorex MVD2042 DVD Player
Skips or won't play disc if even slightly scratched
Hello opie440,
The optics might be dirty or the pickup assembly might need alignment. In the former case you can get an optics cleaning kit and try to clean the laser LED and pickup assembly. For the latter cause you will need to have thre unit aligned at a TV repair shop.
Feb 18, 2008 | Sony DVP-S530D DVD Player
Memorex MP3226 Radio Boombox Logo
136 people viewed this question
Top Memorex Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
