Question about Schwinn Seneca 700c Road Bicycle
How do you adjust the spikes on the rear tire rim to re-align the tire and rim with the bicycle?
    Brigadier General:
  • 8,546 Answers
Spikes?
Do you mean, how do you true the wheel?
http://www.parktool.com/blog/repair-help/wheel-and-rim-truing
Posted on Apr 10, 2011
Chain alignment
the pedal sprocket is a fixed position and the adjustment is done at rear wheel the chain will go out of alignment if rear tire is not tightened correctly which would cause wheel to tilt --bearing in wheel or pedal damaged --
Aug 30, 2015 | John Deere 20 Inch Kids Bike Riding Toy
How to change back innertube on 26" mongoose estes bike
First turn the adjuster on the rear brake handle all the way in and make sure the slots on the adjuster and set nut are lined up, pull the brake cable out and leave it attached to the lever to open the rear brake pads, loosen the bolts on the tire and pull the derailer up to remove the tire, remove the dustcap from tube and using a flat tool (Wal-Mart has tire tools for $1) take one side of the tire bead out of the rim, pull the old tube out, place the stem of the new tube in the hole and put the cap on, tuck the new tube in the tire trying to keep it flat as possible, push the bead of the tire back into the rim. before inflating the tire, put it back on the frame while pulling the derailer up to get the chain back on the cogs( they will adjust later) tighten the bolts and inflate the tire to desired pressure (between 35-60 psi)
Jul 05, 2014 | Mongoose Cycling
2008 street glide rear wheel wobble
Hi Anonymous, and the usual suspects are:
1. Improperly loaded motorcycle. Non standard equipment on the front end such asheavy radio receivers, extra lightning equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tire(s) or improper front-rear tire combination
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. Shock absorber not functioning normally.
7. Loose wheel axle nuts.
8. Excessive wheel hub bearing play.
9. Improper vehicle alignment.
10.Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires out of round or eccentric with hub.
13. Rims and tires out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft nut improperly tightened or assembled.
Good luck and have nice day
Dec 17, 2013 | 2008 Harley Davidson FLHX Street Glide
My 2006 Fatboy front end vibrates above 60mph
Dec 28, 2012 | 2006 Harley Davidson FLSTF Fat Boy
High speed wobble
Sep 29, 2012 | 2011 Harley Davidson FXDWG Dyna Wide Glide
Check front fork alignment
Hi JD, and the usual suspects are:
Sep 21, 2012 | Harley Davidson Motorcycles
Back hand brake rubs on pads cannot adjust basic hand brakes
If you can't adjust your brake position by using the adjustment screws you can loosen the wheel bolts and physically change the tires position to make it fit within the brakes. If that doesn't work take you bicycle into your local bike shop and have them check your rim alignment.
May 06, 2011 | Cycling
Replace and adjust brake pads
Is this disk or brake blocks like cantilever or vbrake. I have disks now b ut have never messed with them. If it is not disk then I would just say to make sure that the rear part of the pad hits the rim first. Fine tuning is done by adjusting the turn buckle where the cable goes into the lever. Set the brakes so that when you are pulling hard on the brakes, on dry pavement, set the brakes so that they only get tight enough to not quite lock up. And make sure you use both brakes at the same time. Not just one or the other. adjust the pads by putting one or two dimes between the pad and rim. There are also adjustment screws on the brake arms that control spring tension and in the end the alignment of tire between the brakes. You want the same space between pads and rim on both sides. If they squeal because you have been riding with poorly adjusted brakes take a file to the pads to level them out. Thy will grab better after this. Hope it helps
Apr 08, 2011 | Fuji Cycling
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Sep 16, 2010 | Dynacraft Girls 16" Barbie Bike
Wheel alignment
you might have bent the rim.
Nov 28, 2008 | 2005 Volkswagen Jetta
Schwinn Seneca 700c Road Bicycle Logo
188 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
