Question about Asound 480W Computer Speaker and Subwoofer Set
The big speaker are very noise - Asound 480W Computer Speaker and Subwoofer Set
  • 27,725 Answers
The speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good and is dust free
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Posted on Apr 10, 2011
Sony TA-215 buzzing speaker sound
Most likely an Electrolytic capacitor. If it doesn't go up or down with the volume control, it will be the big one(s) in the power supply.
Jan 06, 2013 | Audio Players & Recorders
Drivers side speaker not working
Remove the radio and locate the wires that run to the speaker, first check to see that the wires were connected to the big plug that goes in at the back of the radio unit.
if it is connected take the plug loose. carefully strip some of the wire leading to the speaker big enough to place a AA batttery terminals. hold one of the wires on one of the sides of the battery and then tap the other wire (expsed portion) on the other side of the battery, if the speaker makes a noise, then the wireing is fine and the issue is either a setting on the radio. or the radio is faulty. if the speaker does not make a noise, check to see that the speaker is properly connected. if the speaker is connected, do one last test on it before replacing it. remove the connections on the speaker and place small lead wires on it and do the battery test direct.
Jan 14, 2012 | Audio Players & Recorders
High pitched noise coming from speakers after installing stereo
check your wires if they are too near some big power wires and move them away from these high powered wires or check your grounds and make sure its a good ground by scrapping the connection until bare metal. Also its a possibility rca's or wires are getting pinched or not fully connected.
Apr 05, 2010 | Boss BV9560 Car Video Player
The big speaker make noise by itself!!!
Don't think the difference of 18/22vdc would make the noise. Is the noise constant? maybe too close to another device like a microphone or a something that would give off radio waves. Cell phones and cordless telephones. wireless gateways/routers. Try moving speakers away from these types of devices.
Oct 04, 2009 | Altec Lansing AVS 300 Computer Speakers
I have a Rockford PL2-110 and intermittently I get a loud popping noise out of nowhere. the sub sounds good the majority of the time but occasionally it will make the noise more and more often. any ideas?
Have you double checked the wiring ( + to + and - to -)? When hooked up correctly, a sub should push outward when bass hits. If your wiring is correct and your amp isnt too big for the speaker then its about to go out.
Jun 29, 2009 | Rockford Fosgate Punch Stage P312 D4 Car...
Buzzing noise when played on big stereo from cable?
you need a loop bypass filter. you can buy them at walmart for 10-15$
Apr 30, 2009 | Car Audio & Video
Altec Lansing BXR1121
I have same speakers, but only woffer is working, speakers doesnt work. i am really in big trouble.
Apr 24, 2009 | Audio Players & Recorders
Large crackling noise with my Acer Laptops base?
it is ur laptop's cooling fan's noise it is not a big problem.but if it is too much loud then contact on service center.
Apr 11, 2009 | Acer 90.00012.30B Computer Speakers
1989 corvette, engine noise coming thru stereo speakers,
hissing soud is from the altenator ( not a big deal ) have a noise reducer installed or have the stereo rewired for it's power wire from a different location. Very common thing that happens by do it your selfers.
As for oil temp I'm not sure what it should be on thatcar but is it oil tem or oil pressure?
Oct 07, 2008 | 1989 Chevrolet Corvette
Asound 480W Computer Speaker and Subwoofer Set Logo
19 people viewed this question
Top Asound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Asound Audio Player and Recorder Expert? Answer questions, earn points and help others
