Question about Kenmore 44182 / 44813 / 44814 / 44819 37 in. Electric Cooktop
Kenmore 110-44182400 washer fills, agitates but will not empty
  • Kenmore Master
  • 3,051 Answers
Hello there and thank you for choosing fixya
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Posted on Apr 10, 2011
Who made kenmore gas cooktop
Sears roebuck and company.
Dec 07, 2014 | Kenmore Cooktops
Kenmore range indicator light for element does not shut off
Tempature probe(Temp sensor) on that burner is malfuncting . Replace that probe.
www.searspartsdirect.com/partsdirect/brands/kenmore-parts
Jun 30, 2014 | Kenmore White Electric Stove
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
Kenmore 629
Could be the lock needs replacing the oven won't self clean if the door lock isn't functioning it's a safety thing so you don't get your face burnt .
Ray
Apr 16, 2014 | Kenmore Cooktops
Where do i register my new kenmore gas cooktop.
Click on link below then in the upper right you will see kitchen, laundry. Then under that you will see Welcome, sign in or register [My Profile] var pageName=location.href; var index = 0; var pageViewName = pageName.split("/shc/s/"); // if(pageViewName.length>0){ // var page = pageViewName[1]; // var pageURL = page.split("?"); if(pageViewName[1]){ var loginURLs = new Array("LogonForm","UserLogonModalView","LoginRegisterView","LogonFormView","OrderStatusView"); for(var i=0; i Click on the register to register your product.
http://www.kenmore.com/
Good Luck and please rate 4 thumbs for the free answer. var pageName=location.href; var index = 0; var pageViewName = pageName.split("/shc/s/"); // if(pageViewName.length>0){ // var page = pageViewName[1]; // var pageURL = page.split("?"); if(pageViewName[1]){ var loginURLs = new Array("LogonForm","UserLogonModalView","LoginRegisterView","LogonFormView","OrderStatusView"); for(var i=0; i
Apr 19, 2010 | Kenmore Cooktops
Who manufactures Kenmore Cooktops?
HI. Whirlpool Inc, is the principal manufacture for the Kenmore brand.
Nov 03, 2009 | Kenmore 30 in. 42474 / 42475 / 42479...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore 44182 / 44813 / 44814 / 44819 37 in. Electric Cooktop Logo
196 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
