Question about Troy Bilt 5.5hp Self Propelled Mower
Bought a Troy TB110 oush mower at end of last summer. I stored it all winter without opening box. I got it out today, put together and started it. It is leaking oil and blowing white smoke- What do I need to do?
  • tpitts828 Apr 10, 2011
    Thanks!- Heading outside to try it now!
    President:
  • 3,113 Answers
You must have stored it with the spark plug end down. This has caused the oil to get by the rings and on top of the piston. Pull spark plug out and pull starter cord to clear excess oil , put plug back in . Check oil , start mower and let it run until the excess oil burns off and some of it may still be in the muffler. Mower is ok. Some body borrowed my mower and did this resulting in the same problem.
Posted on Apr 10, 2011
How to adjust tappett on tb110
what is the model number of the engine and size of the engine? turn engine over to top dead center loosen the nut that hold the rocker on turn the star head until it gets the gap you want tighten the lock nut and re gap to be sure it is correct. i think it is going to be .004 on both intake and exhaust but check with a parts store to be sure.you will need you model number off of the engine.
May 31, 2016 | Troy Garden
How do you clean the carberator on a tb110?
Take the bowl off of the carburetor take off float and remove needle.
clean the needle the reinstall everything.
That usually take care of the problem with small engine fuel problems.
Jun 10, 2014 | Troy-Bilt Electric Cultivator Tb 154 110v...
How to start a tb110 thats been sitting all winter
Clean old fuel out of carb, some have a 1/2" bottom of fuel bowl bolt that can be loosened to allow draining of carb fuel !, check battery energy level, if their is one, check oil level, and top off as needed to full mark when engine is on level surface, and cold !.( not having been ran ) and activate starting
May 01, 2014 | Troy Garden
I have a Troy Bilt 175 HP 500cc 7 speed riding mower. I just bought a new battery, and it still won't crank. It'll turn over like it wants to, but nothing. I put new gas with the old gas from last season...
If you didn't put fuel stabilizer in gas before letting the mower setup all winter, your gas has gunked up your carb.
You can verify this by removing the air filter and spraying starter fluid in the carb. If it cranks with the starter fluid, the carb is dirty.
Pull the carb and clean it out
Dec 08, 2017 | Troy Bilt 175HP Manual 42" Riding Mower
My troy bilt snow blower that i bought last season (new) ran great i drained the gas at end of winter and this year is hard to start and runs poorly stalls often and bogs down spits and sputters and also...
I am guessing you did not run a gas stabilizer through the unit. Start the unit and run it while spraying carburetor cleaner in spurts into the carburetor. What has happened is that the small amount of gas has dried or what we call varnished causing internal parts to stick. If that fails, removed carb and disassemble and clean, reinstall.
Dec 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Model TB110 rand great first few times but will not run now. Cranks but run rough and dies. Only had 6 weeks. Lowes say they can't help me and I just need to have it serviced! After 6 weeks? Give me...
My name is Dane. Troy-Bilt says this mower has a 2 year warranty with a briggs engine. According to troy bilt, that engine is suppose to start in 2 pulls or they fix it for free. Take it to a local briggs dealer and get them to look at it. I would hate to have you try something and you void your warrenty somehow. Here's the link to the website.
http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_1410819_54968_-1
Hope this helps you... Thanks....Dane
Dec 02, 2010 | Troy Garden
! have a Troy built mower with a Honda engine, it quit running and will not start. I changed the spark plug, it ran for about one hour. Now the mower will not start.
Hello. If the gas has been sitting all winter, remove it with a siphoning bulb and put in brand new gas, not even gas that you have been storing all winter. Also, change your air filter. Finally get a can of starter fluid and a helper. While one person squirts a bit of starter fluid into the air intake [near the air filter] the other person starts it and use more squirts of starter fluid to keep it running. Joe
Apr 09, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Stalls, with oil runing out the exhaust
you have a valve that is stuck in the open position head will need to be removed
then spray valves with wd40 and turn engine over a few times watching to see both valves open and closing,once that is working install head with new head gasket.this is caused by not properly storing the unit. gas should be drained at the end of every season and then ran to burn all gas off from carb and fuel lines once it quits remove sparkplug shoot a tablespoon worth of oil in the cylinder crank engine over for 10-15 seconds to distribute oil on cylinder walls and valves then re install plug now your unit is winterized ready for the next season
Jun 29, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
1,235 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
