Installed a new hot water heater in July and water is brown in one of the bathrooms what is the cause?
    Scholar:
  • 91 Answers
Sounds like your pipe may not be to healthly, internally that is. probably any of the same age will soon end up rusting out as well. Any fixtures in the system that look corroded at the faucet? How old is your home? 35-40 yr old pipes are about as good as it gets.
Posted on Aug 07, 2008
Installed a new kohler pull out spray faucet and the flow is not sufficient to start my instant demand hot water heater. Have taken out the aerator and screen and still not enough flow. Checked the...
Should be valves under your sink for the faucet. #1
Make sure they are opened up enough.
If either device is new, they should support this issue.
Old plumbing can also cause this. Build up in the lines.
They can only be replaced to fix. Some water heaters have adjustable valves, make sure if you have them they are opened as needed. Remember, too low flow can cause over heated water.
Oct 31, 2013 | Kohler K-560-VS Bellera Bellera Pull-Down...
Brown water comes from tub faucet
it may not be your grohe valve it could be your hot water heater check a o smiths web site about rust color water its actually a bacteria
Feb 23, 2013 | Grohe Home
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
What causes pipes to bang when hot water tap opened may be air locks but water seems to flow okay but the noise causes concern
no water hammers installed above the water heater. You can buy these hammers but they are not fun to put on yourself
Apr 08, 2011 | Home
I have a customer who would like a Bosch AE-9.5 tankless water heater installed in the master bathroom. The master bath is located at the far end of the house & they are wasting a great deal of water...
In theory it sounds good, but I don't think it would function properly. Most folks install a low boy 20 or 25 gallon water heater near the master bath and use the home's cold water feed as the supply line. That way, the water for the master bath alone, will always remain hot.Of course this would involve some plumbing modifications.
Of course, the other less expensive solution, would be to insulate the hot water pipe(s) feeding the master bath, from the existing water heater. That way, there would be no heat loss in the pipe(s) so the water in the pipe would remain warm to hot all the time.
Either of the above solutions should heat things up for your customer.
Mar 07, 2011 | Heating & Cooling
We just installed a Rheem 50 gallon water heater. When you use any hot water a low pitched vibrations occurs that you can hear in the bathroom and bedroom. When the water heater completes the heating cycle...
Every electric water heater I have ever installed makes a low hum while heating. I believe this is a combination of the current going through the elements and the minerals in the water cooking on the elements. That is the best explanation I have. Hope this helps.
May 11, 2010 | Rheem 81VP6S/430126 Water Heater
I have installed a 4 gallon inline water heater close to the bathroom. The main hot water heater is at the other end of the house. Now the hot water in the bathroom runs luke warm when the washing machine;...
you don't have a circulating line in it,, there for it is pulling the hot only,, when you have the 2 systems you have to have it circulationg or take 1 out, it being it is hot water they will vapor lock,, meening no hot water , you could get a circulating pump that actually hooks to the cold and hot side under the sink far away from the water heater and it has a timer on it that will circulate the water at certain times of the day,,, this would solve your problem
Jul 02, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
New water heater, shower hot then only warm water in 5 minutes
try this, set the bottom therostat if it is electric , 10 degrees hoter than the top is set , if gas have no ideas
Dec 05, 2008 | Water Heaters
Horizontal electric hot water tank installtion
hello; no, unfortunately conventional elec. water heaters are only designed to operate in the upright position. one alternative is an electric tankless model. but beware there are a few things to explore about them before making the decision.
Mar 29, 2008 | Dayton Electric Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
