Question about Waring Food Mixers
Manual for megamixa plus model HA-3059 - Waring Food Mixers
Wear to find a spare khife for an MaxiMatic HA-3433A Elite Platinum 550-Watt Stainless Finish Meat Grinder
contact the manufacturer through their website support they probably have them available to purchase
Apr 05, 2015 | Food Mixers
Tengo una batidora y ya le cambie los carbones y no me funciona que puede ser
Hola LALOB_RO. Cuando cambió los cepillos (carbones), es posible que haya instalado uno o ambos de ellos para que los cepillos no encaja correctamente. Sólo hay un camino para que los cepillos que se ha instalado correctamente. La caracóncava del cepillo debe descansar por completo en el conmutador de la armadura. Siusted lo ha girado 90 grados demasiado, el cepillo no se asienta correctamente y elmotor no hay nada 'jugo'.
Le recomiendo la eliminación de los pinceles de nuevo para comprobar que ambosestén instaladas correctamente. La ilustración de arriba debe permitir volver a instalarlos pinceles con confianza. Buena suerte, espero que esto ayude. Howard, Burke, VA,EE.UU.
Si esta solución ha sido útil, por favor, valoren, gracias! - hslincoln
Feb 10, 2011 | KitchenAid K45SS Classic Stand Mixer
I can't find the model number of my kitchenaid professional 525 watt 6 quart mixer. I've taken it apart and don't find any numbers that resemble a model number. Any suggestions?
According to the website the model number for a Stand Mixer should be on the bottom and back of the stand mixer.
If you are seeking a Manual for your mixer search here:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KA_EN_CA
Your model number may be KP2672 plus an additional four characters. You can search on the partial model number you have but you will come up with 50 possibles.
Feb 06, 2011 | KitchenAid KP2671 Professional 6 Series...
My kitchen aid mixer is leaking oil
This seems to be a fairly common problem. If you are handy you can replace the transmission case gasket yourself. (Take pictures as you dissassemble it) and expect to get greasy. The website http://www.mendingshed.com/mixergasket.html has the gasket for the 4.5 and 5 quart model. You did not specify what you have. The gasket is only $3.50 plus S&H. They also have a downloadable PDF service manual which is very helpful. Good Luck!
Dec 22, 2010 | KitchenAid Food Mixers
Mi batidora no prende
Hola EBANY780, veo tu pregunta es acerca de su licuadora, pero le fue anunciado en la mezcladores KitchenAid. Mi solución puede funcionar, pero posiblemente no.
Usted ha dicho, "Yo pongo [en] mi pincel" - Supongo cepillo de la licuadora de motor eléctrico(s), así que recomiendo que pruebe lo siguiente.
Sólo hay una manera de volver a instalar los pinceles y eso es lo que tanto el asiento correctamente en colector del inducido o no se va a cualquier jugo "al motor. Véase la ilustración de abajo:99839ea.jpg Si te has vuelto un cepillo de 90 grados demasiado, no encaja correctamente y tendrás el poder para el motor.
En esta ilustración se debe permitir volver a instalar los pinceles con confianza. Buena suerte, espero que esta ayuda. Howard, Burke, VA, EE.UU.
Si esta solución ha sido útil, por favor, tasa que, gracias!
- hslincoln
Jul 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Found a Sunbeam power plus mixmaster in atorage.
I have a 1977 Sunbeam Mixmaster Catalog No. 1-150, service No. 1-15H. Where can I find parts & a manual?
Oct 28, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Missing recipe book
Hi. Goto kitchenaid.com download the manual for your mixer model. Your recipe should be in it. If this solution has assisted you, please rate it
Mar 14, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Where do I get new blades for my Household Blending Mixer HA-3058
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine....
They sell many accessories and you can get blades. Check:
www.bamix.com
www.bamix-blender.co.uk
I have both machines and the blades are identical and inter-changeable between models.
Feb 23, 2009 | Food Mixers
Kitchenaid classic plus mixer
Below is a link that should allow to download a manual.
Let me know if this helped by rating my resolution, or posting me for more information.
http://www.retrevo.com/s/Kitchenaid+mixer+model+k45ss?rt=tr&p=http%3A%2F%2Fforum.kitchenaid.com%2Fforums%2Ftopic.asp%3FTOPIC_ID%3D1548,
Thank you for contacting us at Fixya.com
Jun 10, 2008 | KitchenAid K45SS Classic Stand Mixer
Instruction for household blending mixer
This is part of a kit called the Thunderstick Pro. You may have better luck looking it up that way.
Dec 29, 2007 | Food Mixers
Food Mixers Logo
152 people viewed this question
Top Waring Food Mixers Experts
eyecam
Are you a Waring Food Mixer Expert? Answer questions, earn points and help others
