Question about Briggs & Stratton Briggs Stratton 7 kW Auto Standby Generator
My B&S home generator keeps draining the battery. With a fresh battery, it starts for the weekly test for about 4-5 weeks, and then stops starting. I have to replace batteries every 1 1/2 months to keep the unit running. Any suggestions?
    New Friend:
I had the same problem. Check to make sure the fuses in your circuit board inside the house are still good. They send 240v trickle charge to your battery to keep it running longer term.
Posted on Feb 10, 2013
    Champion:
  • 299 Answers
Rectifier bad.
Posted on Apr 10, 2011
How do you set the day for auto testing from one day of the week to another?
How to Prepare for Extended Generator Runs - EC&M
ecmweb.com/.../...
Electrical Construction and Maintenance (EC&M) Ma...They are also one of the most reliable sources of emergency power for ... Within hours of start-up, we needed to change the fuel line filters. ... After two days into oneextended generator run, the plant engineer came to me and said: "The ... I was anxious knowing that automatic load shed would start if another engine failed.
[PDF]AN007 Automatic start of a generator - Studer Innotec
www.studer-innotec.com/upload/folders/1546.pdf
generator as per different parameters such ... Output power. - Etc... .... Autonomytest in progress {1529} {1530} ... With this configuration you can adjust the time at which .... Program 1 (AUX 1 / AUX 2). Day of the week (AUX 1 / AUX 2) days.
Home Generator Reviews: The Best Whole House Generators
www.mygenset.net/home-generator-reviews-best-whole-house-generators/
How do you find which generator is the right one for you? ... rates, you could be spending $30-$40 per day to run the generator - and that's the low estimate!
How to test your Electricity Generator's AVR, Brushes and ...
? 9:21
https://www.youtube.com/watch?v=tC_LrrZcx38
Oct 21, 2011 - Uploaded by Generator Guru
When your electricity Generator stops producing power, youneed to ... Thanks again, I'll report back in a few days. ... G J van houten 1 week ago .... I didn't loose magnetism, just had to change the avr (because i .... How to get 120v AC out of a caralternator - Duration: 10:23. by kurtscottage 1,188,771 views.
Dec 16, 2015 | Electrical Supplies
98 4runner parked at Denny's went in an ate. Came back and it started missing when I started it back up. It also started draining battery in about a week if you didn't start it during that time
You always start any testing at the battery
Were the coils tested & fail a test?
You did a Parasitic Current DrainTest -for the battery drain issue?
Aug 18, 2014 | 1998 Toyota 4Runner
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Hi, My Kipor 6700TA wont start. Battery died or fuel issue?
It sounds like your unit may not be charging the battery properly.
Try charging the battery and see if it responds properly. If it does, then check the charging circuit. This OFTEN involves a rectifier module which is usually about 1 inch square with four leads. OFTEN there is a fuse, sometimes within the generator housing (stupid place) which protects the low voltage winding.
Here is a hint: Most of these engines have a compression release on the top that one can press then crank up to speed and release. This takes much less effort on the battery. Some have a panel held by bolts. I put hinges on mine for easy access.
REMEMBER the battery is being drained WHILE the unit is running to hold the fuel solenoid open... so if charging isn't working the battery will die.
Test: You should see about 13.75 to 14 volts across the battery when properly being charged while running.
Apr 06, 2010 | Electrical Supplies
Generac home generator does not start. It starts alittle bit but then dies. Maybe runs for 4-6 seconds
is this unit diesel or gas? If its gas driven, the carburetor needs to be removed and cleaned out. Also make sure your gas is fresh. If not drain fuel tank, remove carb, clean out, re-assemble & test. Check fuel filter, oil level.
Feb 05, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Kawasaki Mule 3010, keeps getting flat battery, wont jump start
Sometimes when the battery keeps going dead like that, a component may be creating a current draw. you can do a simple current draw test with a fluke meter by setting the meter to read amps, make sure the test leads are in the proper portals on the fluke for an amp test, and disconnect one of the battery cables and connect the test leads in-line with the battery and cable. It would help to know you have a good fuse inside the fluke. They are easy to blow, and whatever you do, DO NOT try to start the unit with the meter hooked up for the amp draw test. That is how fuses are blown. With the key off, check for any amp draw. If there is, you can start unplugging components until the draw goes away. If there was no draw to begin with, you may have a stator coil (or alternantor, whichever it has) that is weak and can't keep up.
Jun 01, 2009 | 1990 kawasaki ZXR 750
Stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Mar 12, 2009 | Briggs & Stratton 15,000 Watt Home Standby...
I have a slight power surge on my 15,000 ultra source
that linkage is suppose to move. The more power draw the more the linkage moves
Dec 21, 2008 | Ultra Products Guardian Ultra Source...
Speaker Test
Micro-processor malfunction. Take to pro/tech
Feb 23, 2008 | RCA RT2360 System
Briggs & Stratton Briggs  Stratton 7 kW Auto Standby Generator Logo
470 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
