Question about Porter Cable PorterCable BSI525W 5250 Watt Electric Generator
Porter Cable PorterCable BSI525W 5250 Watt Electric Generator Its reading 1.25 volts at the 120 outlets and 2.5 at the 220 outlet. Motor runs fine.
54generator
  • 3 Answers
SOURCE: portable generator low voltage
85 volts represents residual voltage. It is possible that your unit sat for an extended period and lost it's magnetism or the excitation system failed under load. check your manual for a procedure to "flash the field". If that is not successful, e-mail me and I'll tell you how to trouble shoot the failure.
Posted on Jan 04, 2009
joboo1
  • 257 Answers
SOURCE: Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Posted on Feb 08, 2009
  • 1388 Answers
SOURCE: 10,000 watt generator 220 plug doesn't work
Most generators have several circuits incorporated within the windings. There are usually two 115v windings, one or two windings that produce power and sensing voltage for the regulator that supplies power to the armature (produces magnetic force) and sometimes a 12v winding to supply power to charge the battery. The two 115v windings power one 115v plug each and together power the 220v plug. Each outlet has a breaker and or ground fault. Since the 115v plugs are working indicates that the 220v plug must have an open/broken wire or faulty breaker. Easy to check, however you must open cover to wiring compartment and trace wires. Should be easy fix. You do not have to start engine to find broken wire. Use ohm meter instead. With engine off, Insert probes into 115v plug and obtain ohm reading. Then insert probes into second 115v plug and obtain similar reading. Look for same reading at the 220v plug (remember 2 circuits of 115v, ground and neutral). Good luck with your repair and email if you have other question.
Posted on May 10, 2009
pic498
  • 32 Answers
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Posted on Jun 13, 2009
motor1258
  • 6674 Answers
SOURCE: I have a 3500 watt generator with 110 and 220 volt
Yes they should be able to help, but a welding supply shop might be a better idea, just make sure you take a picture or sample of your generator receptacle just in case for reference.
Posted on Sep 02, 2009
What spark plug does a porter cable BS1525w take
The Briggs and Stratton part number is 591043 sparkplug
Nov 30, 2015 | Porter Cable PorterCable BSI525W 5250 Watt...
When I spray starting fluid in carb it starts but won't stay running
It is not getting gas. Check there is gas in the tank, the fuel tap is working and the float in the carburettor isn't stuck.
Aug 16, 2015 | Porter Cable PorterCable BSI525W 5250 Watt...
I have a portercable 5250 generator works great starts great shutts down after about half hour maybe 20 percent load oil good disconnected oil switch, changed feul,carb seems good, bowl clean still...
Seems that you have covered all the bases. The problem that you describe could be related to fuel lock or restriction in the fuel delivery system. Easy to check. Remove the air filter and have carb cleaner ready. If you are near the gen when it begins to quit, spray just a little carb cleaner to see if engine tries to run. If engine begins to run or continues to run with carb cleaner, then suspect fuel delivery problem. If the engine seems to stop quicker with carb cleaner, suspect flooding caused by too much fuel pressure (fuel pushed past the needle due to pressure in the tank; open fuel cap and listen for air pressure release). Fuel delivery problems are caused by collapsed fuel line, restriction in the fuel cut-off valve, restriction at the fuel filter (use larger automotive type), negative pressure in tank caused by no vent at cap. Rare problem with fuel delivery is caused by sudden heat rise at the carb causing fuel to boil out of carb. This is caused by the engine running very hot, lack of air across cooling ribs caused by debris or fan missing blades. You can eliminate the complete fuel delivery system by mounting a small fuel tank on a stand and running fuel line directly to the carb for test. The tank needs to be higher than the carb so that you will have good gravity feed. Good luck
Aug 30, 2011 | Porter Cable PorterCable BSI525W 5250 Watt...
Generator was running just fine. it's a bsv5500-w overloaded the unit by mistake. tested with meter and found 86 volts. shut unit down and now only puts out 5 volts on each leg
are you sure the breaker didnt trip when overloaded,as this is what the breaker is for and would explain the ghost voltage of only 5 volts at the outlet
May 30, 2011 | Porter Cable 5,500 Watt Portable Generator...
THE VOLTAGE COMING FROM THE GENERATOR IS NOT RIGHT. iT WILL BLOW A LIGHT BULB INSTANTLY
Connect a voltage meter to the 115v plug and measure voltage. If too high, adjust governor spring tension to compensate. Your engine developes max horsepower at about 3600 rpm. At this speed the generator should be producting 115v at 60 cycles. Good holidays
Dec 17, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
No electricity from generator
Jun 09, 2009 | Porter Cable Electrical Supplies
Porter Cable PorterCable BSI525W 5250 Watt Electric Generator Logo
50 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
