I am trying to wipe my computer clean with recovery disks provided and i cannot seem to get the process started. it is not automatically starting. how do i get it going to start the process. my computer is an hp 7960 xp i added it came with Me.
  • robert_gray Apr 11, 2011
    thank you it worked!!!! well done
  • 2,574 Answers
The first step is to insert the Recovery disk and reboot the computer.
During the system post tap the F11 key .The key used to access the Boot Menu may vary. Some commonly used Boot Menu keys are F2, F10, F11, and ESC.
You should now see a Boot Menu.Use the arrow keys to select the CD/DVD Rom option from the menu and press Enter to accept.You can now proceed to boot Windows XP from the recovery disk.
Posted on Apr 10, 2011
How can i wipe my entire computer clean and start new?
Hi, have you got clean recovery disks for your computer? Simply put disk into your disk drive and start recovery computer. All data will be erased only system will be like in new computer.
Aug 23, 2014 | Microsoft Windows Vista Home Basic Edition...
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
My apple mac laptop says the hard drive is full . How do I totally restore and start the system again?
Depending on the version of OSx you have;
Pre 10.7 you are provided OSx Disks. Simply insert the Disk and the installer will appear on your screen, run through that, it will reboot and starup off the disk. At the option of installation destination you can change the option to erase the Hard Drive and install.
Post 10.7 you will need to restart/power on your mac and hold the Option key [left of the CMD key] and you will see your hard drive and a recovery partition. Same process after that..
Hope this helps :)
Sep 25, 2012 | Apple Customized 15" MacBook Pro Laptop...
I have been trying to fix my brother in laws emachines desktop computer for 3 days now. It has Windows Vista and Intel Celeron D Processor 356. I used the recovery disc and the computer started working...
The disk is corrupted and it interferes with the install process. Just get this
http://gparted.sourceforge.net/
boot from it and format your entire disk to reiserfs then to FAT32 - this way any trace of the old NTFS file system is thoroughly wiped. Now launch the recovery process one more time and it will automatically detect the FAT32 partition and will reformat it to NTFS in the process.
Sep 14, 2011 | eMachines Computers & Internet
I have several hard drives that came out of non working computers,how do prepare these to work in another computer?
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
http://majorgeeks.com/Free_Disk_Wipe_d5309.html
Free Disk Wipe data cleanup and file wipe tool, that allows you to completely wipe/ remove / delete / erase a selected file(s) on most disks (floppy disks, hard disks, logical drives, etc).
Data recovery software can
Jun 25, 2011 | Computers & Internet
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
Want to restore HP Pavillion 505 N computer back to original
To do a system recovery without recovery disks (not all machines can perform this without recovery disks) press the power button and immediately keep tapping the F10 button until you enter the recovery console.
If unsuccessful, you will need to boot using the recovery disks that came with the machine.
  1. Place the first disk in the 1st CD tray (some machines may have multiple CD/DVD drives) and start up.
  2. Start the machine and immediately press ESC button to enter BIOS
  3. Select the drive the recovery CD is in
  4. Press Enter
  5. Once the machine boots off the recovery disk it will provide several options
  6. Press R for a standard recovery
  7. Press F for a "destructive" recovery (will wipe out and format hard drive)
  8. Press Q to quit
Once you've made your selection, the recovery process will automatically proceed. It may ask for additional recovery disks which have more software.
NOTE: if you are currently able to boot into the machine prior to recovery you should go in and back up any pertinent files. Both recovery options will wipe out personal files.
A link to this information has been provided below. Best of luck.
Greg
HP Recovery
Nov 04, 2009 | Computers & Internet
Compaq Presario Recovery needed??
If the compaq has not had the hard-drive altered, there is a restore partition. Normally you require recovery disks to start this process, but you can turn the computer on, and press F11 repeatedly to access the partition. I'm not sure what will happen without the recovery disks, but it's worth a try.
I am assuming the Compaq/HP system restore utility in Windows is long gone?
Sep 07, 2008 | Computers & Internet
I am trying to delete everything on the hard drive and start over
It sounds like your recovery disk is damaged or scratched.
Hold the disk, data side up, and look for any small scratches or finger print smudges.
You can clean it with a soft cloth and warm water, by wiping from the inside out (don't wipe "around" the disk).
If it has scratches, you can find a disk repair device at most Audio / Electronics stores (like music stores) and try cleaning the scratches off that way.
If the damage is too severe, you may have to see if you can find a different recovery disk, or you may have to pruchase a copy of Windows to install.
Aug 01, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
