Question about Microwave Ovens
I have a Westinghouse steam oven model 222110 which has never been used due to the water bottle feeding all its contents into oven within 10-15 minutes
How do I unlock Miele steam oven when it has not been descaled within the 10 reminders
If you would like to get some details about microwave oven repair and service then check the following link.
http://electro-medical.blogspot.com/
Jun 27, 2016 | Miele DG4084 Classic Design 24" Steam Oven
What causes steam in between glass microwave door
Cooking food in there will cause steam as the microwave heats the water content in your food to make it hot. This will mean some escapes and will settle somewhere it can find cooler than the rest of the unit
Oct 07, 2014 | Microwave Ovens
No steam coming out of iron, does it need descaling and if so how do you do it? Thanks Iron is Wahl zx506-1
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Aug 25, 2011 | Microwave Ovens
Fissler Pressure cooker has steam coming out from the Utimax valve, is this normal?
Hi. Some steam is ok. But when it is running it should be sealed up. The little rocker should be doing it's thing too. Good luck.
Jul 25, 2011 | Microwave Ovens
I usually freeze my milk, to save daily shopping, Yesterday I bought a different make and it says on the bottle of milk 'not suitable for home freezing'? Unfortunately I put it in the freezer when...
Although this question is not really suited to FixYa, the answer is that when you thaw it the fat in the milk will separate and float to the top. It's really a quality issue rather than any health problems. You will not get sick by consuming it.
Freezability in regard to milk depends upon the fat content and how it's been homogenised within the milk, and these factors vary even within products within the same milk brand. In general, skimmed and semi-skimmed freeze best.
Jun 23, 2011 | Microwave Ovens
How many watts are on the wst3501 microwave oven?
Westinghouse WST3501 Microwave Oven 0.7 model or 700 watt
Good luck (remember to rate this answer).
Apr 08, 2011 | Westinghouse WST3501 Microwave Oven
Our lg microwave Model LMVa925SB seems to cut out when starting it all the time and we have to reset our outside power switch. My husband changed the switches as told by a home depot person to another...
You may have an "Earth Leak". That can be caused by, in microwave ovens, spilliage on the turntable motor causing a "leak of mains power" to Earth and tripping the RCD switch.
Have a look at the motor from underneath where the inspection cover can be removed.
Or
a leak from within the appliance itself due to leakage of boiled over/steamed food. It is clearly not safe to use as it is.
Dec 22, 2010 | LG Microwave Ovens
Ive brought a avent streliser but threw thin instuctions away i dont know how long to strelise the baby bottles for in the microwave
I googled it, here's what I found from e-how. Hope works for you.
Avent Bottle Sterilizer Instructions
By Christine Lehman, eHow Contributor
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Many parents like to sterilize their baby's bottles before use. Avent makes baby feeding equipment including bottles, nipples and breast pumps. They also make steam sterilizers that can be used to sterilize these items before use.
The Sterilizer
1. It is important to be familiar with the components of the Avent sterilizer before operating it. The base of the unit has a stem on which the racks holding the bottles (or other things to be sterilized) are placed. The bottom rack slides on the stem and lies near the bottom of the unit. It is made of mesh and will allow steam to rise through it while keeping the contents on the rack. Three other racks are available: two flat mesh racks (which look just like the bottom rack) and a rack with rings to hold bottles in place. Spacers are placed on the stem to separate the racks. If you wish to have more room between the racks, simply use more spacers. A lid fits over the entire unit.
Sterilizer Use
2. To use the sterilizer, the reservoir first needs to be filled with 90 milliliters of water. Using exactly this amount is important because if you use less your sterilizer may not work properly, and if you use more the cycle will take much longer than normal. There is a line in the reservoir marked "max" that should remain at or below the water line. You can use the milliliter marks on one of your Avent bottles to measure this volume exactly. Once the water is in the reservoir, assemble the baskets in whichever configuration suits your needs (for example, use only the mesh separators if you are sterilizing your breast pump and use the bottle rings to stand any bottles up that you are sterilizing) and load them into the unit. If you have small items to sterilize, also sterilize the pair of tongs that comes with the unit. Place the lid on the sterilizer. Plug the cord into the sterilizing unit, then into the wall. Turn the Avent sterilizer on and wait for it to cycle. Although the duration of the cycle will vary from load to load (small loads take longer to sterilize), this should take approximately 8 minutes.
After Sterilization
3. Wait 3 minutes once the cycle is over before opening the Avent sterilizer. Before then, the unit is extremely hot and the steam could burn your skin. In the meantime, unplug the unit and wash your hands. Remove the lid carefully and begin removing the items from the sterilizer, using the sterilized tongs if necessary. If you do not remove the lid immediately, the items in the sterilizer will remain sterile for up to 3 hours after the cycle is complete. Once the sterilizer is empty, pour the remaining water out of the reservoir.
Dec 18, 2010 | Microwave Ovens
Cleaning vents
GE Spacemaker Profile X1800.
I would take out the grills and boil them, but cannot see how to do that.
Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Wst 3502
Does it seem like the unit is actually responding in any way when you press another key?
It sounds like a shorted keypad, like the Power key is shorted.
This can be due to wear or moisture, most often from cooking steam or spraying cleaners directly onto the keypad.
You may find it's not economical to repair this, as parts may be unavailable separately.
If you have the manual, you can contact their support line to see.
Nov 04, 2007 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
