Question about HP Computers & Internet
Sound card not working - HP Computers & Internet
  • Tony Apr 10, 2011
    model #?
  • HP Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 10, 2011
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
I have a Dell Dimension 4600, will a PCI Express sound card work in place of the original Sound Blaster 5.1 sound card
Well, the short answer to your question is "No, it won't work". The Dell Dimension 4600 does not have any PCI Express slots in it, therefore you can't install it, and therefore it won't work. But, if you installed a PCI sound card, it would work. The BIOS would recognize the add-on sound card, disable the onboard sound, and your sound will start going through the expansion card instead. Hope this helps.
Jul 18, 2009 | Dell (8H390) Sound Card
New Sound Card is not working.
Ted, the first thing you should do is go into your computer's BIOS and disable the built-in sound card. Once you do that, go back to your device manager and if the onboard sound card still appears there remove or disable it. Then reboot and your new sound card should be recognized and you can install drivers and begin using it.
Apr 25, 2009 | Computers & Internet
Sound card problem
Does the Device Manager display this sound card, otherwise try adding hardware to and let it choose the driver automatically thru the net. Try cleaning the slot metal contact points with any clean paper, re-insert and try. If nothing works try any other sound card & if that works then most probably your sound card has got fried. Also if you are using Vista, not all sound cards are recognized by this OS and there is no way of installing a seperate driver...so all the best...........sodeep
Mar 20, 2009 | Dell Sound Blaster Card
Sound card are not working
try downloading new drivers for it if doesn't work i would say maybe your sound card took a dump it happens sometimes lala linda
Jan 05, 2009 | Creative Labs Sound Blaster Live! 5.1...
Microphone and external bose speakers stopped working
it is not by sound card only ,check the sound utilities,driver ,and master volume control,
if all correct just remove the side panel (if u have PCI sound card or separate sound card) and remove the sound card and replug it,
if now not working u call to technition
regards
prasanna
pk86bhat@rediffmail.com
Feb 26, 2008 | Acer (54.AA806.001) Sound Card
Sound
the sound card is to be attached to the isa slot, if working should receive its resource and work, carefully attach the sound card to the isa slot, if working sound card it will be read if not it won't then put a working sound card.
UZOWUANYA
e-mail uzowuanya@yahoo.ca
Feb 15, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
PCI card not been detected via Windows.
the sound card is installed into the ISA slot not the PCI slot.
clear the cmos for a minute, set it normal again.
install the sound card to the ISA slot carefully - i mean a working sound card and couple the system unit and boot, surely you will have your sound card working.
UZOWUANYA
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | ASUS A8N-SLI Deluxe Motherboard
AC 97 Sound card turned off by code 10 error ?
A code 10 is so broadbased that Microsoft has this posted on its website. Please try the suggestions.
http://support.microsoft.com/kb/943104/
Jan 01, 2008 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
