Question about Schwinn Original Airdyne
We have lost our manual and need to reset the program.
  • 456 Answers
Hi.
the link below takes you to the schwinn website. click product manulas towards the bottom of the page and select your model and download the instruction manual in PDF format.
hope this helps
Posted on Apr 10, 2011
Testimonial: "I found a manual and was able to get the bike set up again. Thanks for your help!"
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
Tip
HTC Touch Soft Reset Soft Reset Occasionally, you may need to reset your...
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
____________________
Download the HTC Touch Manual.
HTC Touch Clear Storage.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
The timer blinked low battery, we replaced the battery and now it needs to be reprogrammed but we have lost the manual. How do we reprogram it?
You posted under ST01C timer.
Open following page to read ez steps and download manual.
Unless you reset the timer, then programming will still be saved forever.
Even if battery was dead, programming remains saved inside timer until timer is reset or stops functioning.
So all you need to do is set current time.
If the timer will not work, then reset timer.
Mar 27, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How to remove align screen
Hi..
Problem can com from your touchscreen panel.
you need to replace it manually. only then this will be solved.
or you can try with soft reset or hard reset.
please find explanation at below :
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings - the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
programs will remain.
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard resetHard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
hope this kind information will be help you to solved
regard,
adhiwahyudy
Dec 24, 2010 | i-mate JAQ3 Smartphone
I LOST THE MANUAL, HOW TO RESET THE NEW NUMBER?
I LOST THE MANUAL FOR THE 'HARDLINE' DIGITAL ELECTRONIC SAFE. HOW TO RESET A NEW NUMBER?
Dec 22, 2009 | Safe International Digital Electronic Safe...
My Cash Register Sharp ER-2386 show me just a 0 instead 0.00 How can i change it?
YOur register lost the program or it has no battery power and was left unpluged. If you do a master reset it will all come back. At the moment it is most likely the program is corrupted and needs a master reset. It is done by turning the key (if you have a service key) to the blind position and holing down the journal key and plugging the machine back in, oh yeah you are suppose to pull the plug first. then program in the time and date and what ever else you may wat
Chris
Jun 04, 2009 | Casio Parts Cash Register PC Desktop
Uniden telephone answering machine
Replaced my battery for my Uniden 900MHz phone and lost my instruction book..Need to program it again for memory numbers.
How do I do that?
Feb 23, 2008 | Uniden Cordless phone EXS9950
Schwinn Original  Airdyne Logo
943 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
