Question about Hayward SAND FILTER, PRO SERIES
How do i drain my inground pool with this system
    President:
  • Hayward Master
  • 1,378 Answers
Valve off your skimmer(s) so only your floor drain(s) is open and set the valve to waste. Your pump should then drain the pool out the backwash line assuming nothing leaks and the valve effactively shuts off any skimmers.
John
Posted on Apr 11, 2011
How to close an inground pool?
The only tool needed is a blower to hook up to the inlet lines to blow the water out of them.
you basically drain the pump and filter of the water and heater if you have one.
Rod
US Parts Center
Feb 05, 2013 | Pool & Spa
Tip
How to Last Minute Rush an Inground Pool Vaumning
Did you ever want to just get the pool vac'd., without getting out the robot if you even have one, or pulling out the vacumn and hooking up the hoses, having to purge all the air out of the system just to get it ready.....you know the drill....and to make matters worse its real hot out!!
her's what i have found in my years of pool cleanup blunders, Put the pool selector valve to pool drain, get a long adjustable handled pole with a leaf type pool brush attachment, very slowly push the grit on the liner towrds the pool drain, do it gently and stop, wait until the smokey looking water clears(this means it went into the drain port and is being filtered out in the cannister).
Do this to the entire pool but dont rush it, after you are done check the PH and Chlorine etc. adjust, backwash the filter if your filter has a backwash system, and off you go onto another home project, this one just saved you a ton of precious time!!!
If you have the inground pool cartridge filter system you should remove the filter/filters and hose them out twice a year to keep them clear, when they start to look and act dirty and they cant get clean by hose take them to a pool pro and ask him to chemical bath them, thisfilter problem will be noticable when you see the pressure rising too high on your filter tank, it means the filter/filters are getting clooged and need attention.
Happy Homeowning!!
on Jun 14, 2010 | Pool & Spa
Spa Drains Down to Pool Level
install check vales - this will stop the water from leveling off between the pool and the spa
May 22, 2012 | Pool & Spa
I have 2 inch PVC system for my pump and filter. Fafco inground system has 1.5 inch piping. Where is the best way to reduce 2 inch pipe to 1.5 inch (at the diverting valve or at the panel)? Another...
Honestly, I think you are over thinking both your problems. Reduce to 1.5 inch pipe as close to the ground as possible. It is more work for your pump to push water up a 2" pipe then a 1.5" pipe, but it will do either without any real problem.
As far as mounting your panels, as long as they are above the water level of the pool the water is going to drain out of them just fine. You can slope them slightly, but you don't need to.
Apr 16, 2011 | Fafco Inground Deluxe Solar Heating System...
How do I drain the water from my Hayward heater for the winter
There should be a drain plug on the bottom of the header. This is common on most of Hayward's in-ground pool heaters. Since you did not give your model Number, I can't say 100%. You can also check Hayward's website for the manual and look under "winterization". you should be able to find your product manual here: http://www.haywardnet.com/inground/products/manuals.cfm#HeatersGas_Heaters Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 01, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Inground pool liner
need to drain the pool pull up the trim see if you can stretch the liner back into position (works best on hot sunny day doesnt work at all in cold weather). Alot of pools have a u shaped groove the liner goes into then plastic tubing is hammered into the groove (a similar application is screens for windows and the spline that holds the screen in place). I also use a shopvac to "pull a vacuum" on the liner to help pull into sides of pool before filling. If your liner is more than a few years old or was trimmed too short you are probably out of luck
Aug 04, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Need to get water of the bottom of the pool
there is a drain hole at the buttom of the deep end. need to clean out the drain before turning on the pump.
May 08, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
175 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
