Question about Locks & Locksmithing
I have a Larson Intevia Keyless Electronic Lockset Model 6101LM and cannot seem to get it to program at all. The instructions are vauge and do not hear any beeps as it states in the instructions.. PLEASE HELP!!
Yes reset all codes out push 1 and inside button then push 1357 11 then your 4 digit code then repeat should work
Posted on May 30, 2011
  • 1 more comment
  • nbrock Jun 10, 2011
    Same problem - above solution didn't work. Do you mean push 1 on exterior and push the button on the interior at the same time, to reset the procedure?
  • tdrillstone Dec 30, 2011
    What a waste of money and time!
  •  S Morgan
    S Morgan Jan 20, 2012
    Had the same problem. Held 1 and inside button at the same time until I heard a beep. Then I was able to set my own programming code then entry code. It worked for me.
    Thanks for posting your question.
    It would help if the instructions told you how to reset the lock.
I have a Larson Tradewinds w/ Intevia Keyless Lock Model 6101LM.All of a sudden you cannot lock it from the outside using the user code.
Once you remove the battery you will need to get the nearest agent to reset your Vehicles computer to make it work correctly again. Best Wishes, Malcolm Campbell.
Aug 20, 2017 | Cars & Trucks
Have a Intevia keyless lock set model 6101LM, have changed the batteries and lock set will work for couple of minutes. After that unit will not work
What happens when you change the batteries again? Maybe those were faulty batteries? Also, there might be a short that is draining the batteries quickly. Are the batteries warm to the touch when you remove them?
Feb 02, 2015 | Locks & Locksmithing
Intevia 6101lm
First thing to check is the batteries are not too run down to operate the lock properly.
Aug 03, 2014 | Locks & Locksmithing
I have a Larson storm door with an Intevia Keyless lockset. The door handle assembly comes apart, i.e. when I pull on the outside door handle it comes completely out of the door! How do I fix this?
I've been unable to find any installation instructions or diagrams for your lock. However, here is the customer service contact information. Call them:
Homeowner Helpline:
1-800-352-3360
Monday - Friday
7:30am - 4:30pm CST
Feb 27, 2012 | Locks & Locksmithing
Larson keyless lockset
I'm going out on a limb and guessing that this is the model number and instruction sheet for your lock. It may take a few seconds to load:
http://www.larsondoors.com/files/etouch-user-guide.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Jan 11, 2012 | Locks & Locksmithing
I have a larson storm door with an electronic lock its an intevia model 6101LM it is locked and I cant get it to unlock with the code outside, interior push button, or the manual overide. It just beeps...
I have reviewed the programming & installation instructions and nowhere is your particular situation described. For your convenience, here is the link to online instructions:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Note what the instructions have to say about the batteries:
"4 AAA Energizer Lithium batteries are required to
maximize battery life and performance at temperature
extremes. AAA alkaline batteries
are not recommended and should not be used."
So, I recommend contacting Larson Door Customer Service and allow them to help you with this problem.
Homeowner Helpline:
1-800-352-3360
Monday - Friday
7:30am - 4:30pm CST
Good luck--and please provide feedback if this helps!
Sep 04, 2011 | Locks & Locksmithing
Setting keyless electronic lock by Larson 6101LM
Here is a link to the instructions for the 6101LM:
If you are not successful after changing the battery and following the instruction sheet, then I suggest contacting Larsondoors.com for Customer assistance.
Homeowner Helpline:
1-800-352-3360
Monday - Friday
7:30am - 4:30pm CST
Aug 28, 2011 | Locks & Locksmithing
I have larson keyless 6101lm cannot program
Homeowner Helpline:
1-800-352-3360
Monday - Friday
7:30am - 4:30pm CST
Aug 09, 2011 | Locks & Locksmithing
We have a new Larson Storm Door with an Intevia Keyless Electronic Lockset. We know that it is working as we can hit the button once on the inside and it will lock and like wise we can hit it again and it...
I MESSED AROUND WITH ONE OF THESE LOCKS ON A LARSON STORM DOOR LAST SUMMER. IT ATE LITHIUM BATTERIES FASTER THAN I COULD BUY THEM. DO YOURSELF A FAVOR AND REMOVE THE LOCKSET, LIMBER UP YOUR ARM AND THROW IT AS FAR AS YOU CAN. CALL THE FACTORY AND TELL THEM YOU WANT A MANUAL LOCKSET FOR YOUR DOOR. I DID THIS LAST FALL AND HAVE HAD NO PROBLEMS SINCE!
May 01, 2011 | Garden
I want to change the code
This link will take you to a video on how to program the lockset:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#13
Mar 17, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Locks & Locksmithing Logo
2,328 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
