Question about FrancisFrancis! X6 Espresso Machine
I need to decalcify my Francis Francis X1 espresso machine. I need to know what product to use and how to do it. I assume that I merely place the product in the reservoir (how much?) and run a few cups of water (how many?) through the machine. The instruction book only says to decalcify the machine every three months. It does not say how to do it. Thanks. Ralph
jmgldsmth
  • 1869 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
SOURCE: Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Posted on Mar 12, 2008
  • 10 Answers
SOURCE: francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Posted on Apr 01, 2009
  • 1089 Answers
SOURCE: my francis and francis is leaking and the espresso
Hi
Try calling Illy at 877-469-4559. They can help you get your machine fixed.
Posted on Jul 16, 2009
SOURCE: I bought a second hand Francis Francis X1 Espresso
Perhaps the heating element is broken. Does it heat up at all? If not, the steamer won't work and there will be nothing for the gauge to register.
Posted on Feb 09, 2010
My francis Francis X1 constantly drips water from the steam wand. i've decalcified and decalcified. Any help??
The problem is with the two O ring which are on the steam knob srew. So you need to disasemble the steam knob srew by turning it all the way reverse. On the srew axis you will find two O rings which must replace. You can fint easy replacements O ring from DIY shop they usuly have O ring kits with diferent sizes so take one with youto match it with that of the shop.
Feb 22, 2012 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 pump replacement.
http://www.craystone.com/francis/francisfrancisfaq.html
for spares Espresso Parts, Tel: 0870 3851531
Oct 20, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 Gasket broken
Hello Salmonp,
You can contact Empire Fulfillment at 877-855-4540 for all of your Francis Francis machine needs. The are the authorized service center for Illy cafe and the FF machines.
Aug 05, 2009 | FrancisFrancis! X1 Espresso Machine
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis X1 overheat quickly
hey. you have calcium build up on the wands that go in your boiler so they can't messure the temp properly so it keeps heating.buy a decalcifier from any coffee site online or coffee machine sales and repaires place.
Dec 14, 2008 | FrancisFrancis! X1 - Stainless Steel...
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X6 Espresso Machine Logo
56 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
