Question about LG 32LG30 32 in. LCD HDTV
A four inch vertical black screen on the right side of tv
  • 52 Answers
Im Pretty sure in the menu screen there is an adjustment, That is assuming that the picture is adjusted to far to the left, Go to a Tv guide channel and try reading, See if you can read the complete listings?
Posted on Apr 10, 2011
praky16
  • 744 Answers
SOURCE: Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Posted on Jun 01, 2009
  • 1779 Answers
SOURCE: I have a black vertical line on the right side of
Black Vert line usually indicates a bad LCD display, which is as much as a new set.
Posted on Jun 30, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
I had one vertical line it cam and went for awhile then stayed permanently and I took it in for repair only to be told they couldn't fix it now they are trying to give me a used tv (warranty don't want to pay) but I refuse I purchased it new and I told them I want a new one. I had that tv less than 2 years. So if you have a warranty and lines get it in fast.
Posted on Mar 26, 2010
agibbsholden
  • 30 Answers
SOURCE: sky 42 inch plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Posted on Oct 30, 2010
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
hi...
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
LG 32LG30 32 in. LCD HDTV Logo
90 people viewed this question
